Engine block heater
Old Jan 31, 2008 | 10:11 AM
TheePlaymaker's Avatar
TheePlaymaker
Default Engine block heater
So i'm thinking about getting one they're only about 30-35 dollars online depending on where you look and i was just wondering how hard they are to install. Does it involve drilling into anything or what not or is there a spot for them already. 2000 4.7 club cab. Thanks
Old Jan 31, 2008 | 08:16 PM
mikec04's Avatar
mikec04
Default RE: Engine block heater
Generally, a block heater will replace a frost plug. There is usually a specific plug with the heating element pointed in a specific direction (12 o'clock, 1 o'clock, ect.)
some installations require the heater to be placed behind or very close to the motor mount. Best advise is to visit your favorite local parts store and look at the install instructions before purchase. There might be a cost savings buying it local (no shipping, ect)
Old Feb 1, 2008 | 02:18 PM
SmokedRail07's Avatar
SmokedRail07
You really don't need one.
Old Feb 1, 2008 | 05:19 PM
TheePlaymaker
yeah i've decided after further reasearch that i think im gonna pass
Old Nov 19, 2008 | 12:04 AM
jlampitt's Avatar
jlampitt
Question When is block heater needed?
Found this thread after I've entertained putting one in my '03 Quad Cab. How cold does it need to be (on a consistent basis) to warrant putting one of these in?
I live in Colorado around the 6500' level. I'm not in the mountains, but it can still get butt cold around here.
Old Nov 19, 2008 | 10:26 AM
TheePlaymaker
eh the main thing on a gas engine is for heat right as you start it or soon after...i was just looking into these again this week haha but decided again against it. i'd say it couldn't hurt though if your constantly below freezing...although a battery heat blanket might be more of a better choice because its harder on a battery when its damn cold out.
Old Nov 19, 2008 | 04:57 PM
batman13's Avatar
batman13
i just put a winter front behind my grille and let the truck idle 5-10 minutes before going anywhere, gas mileage sucks but its warm, and better for your engine, you shouldnt drive them cold,
the temperature differential means your engine components are under stress since different metals expand/contract at different rates when hot or cold, so you wear components faster than under "normal" conditions.
so once the engine begins to warm, everything becomes "balanced" so everything wears as it was designed to.
gas engines dont need block heaters, and battery warmers are really only necessary when it gets around 0*F and stays there.
diesels only really need them because the fuel dosnt combust with a spark, so the temp needs to be higher.
at work we store the tractors we use in the winter inside, and we let them idle up after starting (after we pull them outside of course)
Old Nov 19, 2008 | 11:52 PM
jlampitt's Avatar
jlampitt
Thanks for the input!
Old Nov 20, 2008 | 12:33 AM
big.bryant's Avatar
big.bryant
yeah dude, i have started up on some pretty freaking cold mornings but have never found the need for a block heater... i wouldn't worry about it and if anything just get a new/better battery for those cold starts...
Old Nov 20, 2008 | 12:35 AM
rtdakota2001's Avatar
rtdakota2001
optima FTW! seriously, think of it more as of an investment into your truck.
