No Starty Starty
Old Feb 6, 2008 | 12:50 AM
brbcbrent's Avatar
brbcbrent
Default No Starty Starty
So I left my lights on at work today which ran the battery down, obviously she's not going to start that way. Hooked up the jumpers to our diesel work truck and she cranks strong but will not catch. I had been having some problems with the fuel pump relay though usually if I frig with it a bit the pump primes and she'll start. Not sure how to go about troubleshooting this one. Cap, rotor, plugs and wires are all less than a year old and I am pretty sure I can hear the pump priming when I turn the key 'on'. This one has me confused. I even swapped out the relay for another one (the A/C relay) but no luck. Any suggestions would be welcome.
Old Feb 6, 2008 | 12:15 PM
brbcbrent's Avatar
brbcbrent
Default RE: No Starty Starty
Hey I finally got it to throw a code out: 1282 - Fuel pump relay open/short circuit. What should I be looking for to solve this?
thanks
Old Feb 6, 2008 | 12:24 PM
batman13's Avatar
batman13
if changing the relay dosen't work, check any connections in the panel
Old Feb 7, 2008 | 12:50 AM
brbcbrent's Avatar
brbcbrent
OK, I unhooked the negative side of the battery and left it off for a few minutes then reconnected it and let the computer reset. She fired right up and I got her home. Though in the back of my mind I didn't actually solve the problem. Could the problem still be a poor connection at the panel?
Old Feb 7, 2008 | 01:27 AM
rfry's Avatar
rfry
if you think its electrical the first place i always look is ground.
Old Feb 7, 2008 | 10:40 PM
ccrunner's Avatar
ccrunner
Yeah, although I'm assuming thats what he just did.
Old Mar 15, 2008 | 11:50 PM
brbcbrent's Avatar
brbcbrent
OK sorry to throw this back up on top but it happened again. I can keep it running ifI stay on the gas pedal but as soon as I let off she stalls. Doesn't sound rough when I'm on the pedal, it almost seems like the base line RPM's are set too low to keep the motor running -- does that even make sense? I am really stumped on this one....
Old Mar 16, 2008 | 12:07 AM
varsis's Avatar
varsis
ORIGINAL: brbcbrent
OK sorry to throw this back up on top but it happened again. I can keep it running if I stay on the gas pedal but as soon as I let off she stalls. Doesn't sound rough when I'm on the pedal, it almost seems like the base line RPM's are set too low to keep the motor running -- does that even make sense? I am really stumped on this one....
Sounds like your not getting enough fuel, also check for codes, sometimes they get stored but no CEL.
Chris
Old Mar 16, 2008 | 12:57 AM
imnothot02's Avatar
imnothot02
tps
Old Mar 23, 2008 | 02:49 AM
00DakR/T's Avatar
00DakR/T
If you are having that code, you could also be looking at a bad fuel pump
