Oil pressure problem.
RE: Oil pressure problem.
ORIGINAL: shane_slone2000
Hey guys...thanks alot for all the help, but it turned out to be simply a loose oil filter.
Today i changed the oil again and took the oil filter off, no double o-ring, but it was a little loose. I re-installed it with alot more pressure this time and re-filled with oil, and have been on 2 drives and no problems and its holding oil good, according to the stick.
I have another ? though... i am about run some seafoam through.. but i have no idea where to pour it? i think i read maybe the brake vacuum line or something? could someone please explain where exactly this is? Thanks alot
Okay so i ran the seafoam through... not as much smoke as i expected...not sure if i did it right tho?
I mixed 1/3 in oil gas and vacuum hose...and let sit for about 25 mins (didnt mean to wait that long but was busy) then when i started it, it only gave a slight amount of smoke...even when running hard. it began to smoke alot while i was letting the truck idle and feeding it tho....did i let it sit for too long?
Either way.... i cam def tell it is alot peppier.
If anyon can help me and tell me if i let it sit too long or what... i really expected a smoke show...
