Nerf Step and Cab Mounts
Old Mar 16, 2008 | 09:16 PM
Cdn Colin's Avatar
Cdn Colin
Default Nerf Step and Cab Mounts
Some clown in a parking lot schmucked up my side bar and took off. Thankfully, the bar did its job and protected the doors, but now I'm looking at replacing the bars. I'm not too upset; they're getting pretty rusted and unseemly from the salt anyways.
The issue I'm having is that the bars are mounted to the cab mounts. There seems to be a bolt going up through the bar bracket,through the cab mount and into the cab. The issue is that I can't get at the top of the bolt, so if there's a nut up there, I can't reach it. Is the bolt threaded directly into the cab? If not, how does the bolt come off/on?
I'd rather not start pulling things apart and mess everything up. I've done a search through old forums, but can't find anything on this topic. Any suggestions are welcome.
Old Mar 16, 2008 | 10:15 PM
murdoc chongo's Avatar
murdoc chongo
Default RE: Nerf Step and Cab Mounts
I dont know if this helps but when i installed my cab mounted nerf bars, they had lockwashers with the nuts. What brand of nerf bars are they or are they factory? And where exactly do they mount on the underside of the cab?
Old Mar 17, 2008 | 09:03 PM
Cdn Colin's Avatar
Cdn Colin
Default RE: Nerf Step mounted to Cab Mounts
I have Tech-tubes that I'm replacing with UltraBlacks from Dee-Zee.
The bolt that holds them on is the same bolt that holds the cab onto the frame. I can't see how to reach the top of the bolt, so I'm wondering if the cab has the threads built into it, therefor no nut to try to reach.
Old Mar 17, 2008 | 11:21 PM
imnothot02's Avatar
imnothot02
get the cheapest ones you can on ebay, they never last, they all rust, why pay 400 for dee zee unless your gna clean the thing religously...then replace in 3-5 years, when you can spend 150 and do the same? this is what i did just my oppinion...i had the dee zee, junk, the thing came off whenit wasused as a step, not impressed.
Old Mar 18, 2008 | 11:03 AM
jnwolf2000's Avatar
jnwolf2000
I've never looked at the cab mounting bolts, but my understanding is on most trucks there is a captured nut in the cab. They run the bolt up from the bottom into the captured nut.
If you have a repair book it may provide a little bit of detail on the cab mounting, or talk to the parts department at your Dodge Dealer.
Good luck.
James
Old Mar 18, 2008 | 05:06 PM
imnothot02's Avatar
imnothot02
ORIGINAL: jnwolf2000
Good luck.
James
You are correct however on dakotas this isnt true its just a single bolt
Old Mar 19, 2008 | 08:12 PM
Cdn Colin's Avatar
Cdn Colin
If there's no captured nut, what does the bolt turn into? I can't see any way to access a nut in the mount.
Old Mar 19, 2008 | 08:39 PM
imnothot02's Avatar
imnothot02
what?!
Old Mar 19, 2008 | 09:21 PM
BlackOut04's Avatar
BlackOut04
There is no nut at the top. just unscrew it. just use a 19mm or 3/4.
