42re
Old Mar 25, 2008 | 10:17 PM
varsis's Avatar
varsis
Default 42re
Hey,
Just a thought here, how much can these trannies handle? I might just do the v8 swap if I can't sell my truck...
Old Mar 25, 2008 | 11:04 PM
moe7404's Avatar
moe7404
Default RE: 42re
one more time
moe in wichita ks
get in touch with these guys. i have known them from the 60 s they are honest. 90% of ALL trans shops get parts from a & reds. they will know the answer to any question.
Contact: 1-800-835-1007
email orders: parts@areds.com
Old Mar 26, 2008 | 12:31 AM
varsis's Avatar
varsis
Default RE: 42re
I would email them but my email doesn't work.... Il try and search up wikipedia if not il contact them when my email works...
Old Mar 26, 2008 | 09:29 PM
f0x672's Avatar
f0x672
Default RE: 42re
baby the throttle with the 318, it will hold up, weekend warrior, be prepared to jsut wipe out the 42re, 360 will just kill it imo
Old Mar 26, 2008 | 10:23 PM
varsis's Avatar
varsis
Default RE: 42re
ORIGINAL: f0x672
Well I talked to someone who did the swap and they still have the 42re in there. And they don't have a shift kit, but i do.
Old Mar 26, 2008 | 11:42 PM
wink2873's Avatar
wink2873
Default RE: 42re
alot of people who do v8 swaps still use the 42re, it's pretty strong. you would more than likely blow the rear before the trans. just make sure your trans fluid is at the proper level and clean, it should be fine.
Old Mar 27, 2008 | 01:47 AM
varsis's Avatar
varsis
Default RE: 42re
ORIGINAL: wink2873
I have the 42re, rebuilt, shift kit, (kicks pretty good), tranny cool (The bigger one double the cooling flow of the normal sized one.)
I have the 8.25 rear, and I know they put these with the v8's so I think it will be okay. I know someone running a hemi with the 8.25 rear, and it's still holding up (about 400 hp at the crank.)
This all depends if I sell the truck or not, if I don't I am going to make this thing sweet. SAS(dana 60 and 44), 5.9L magnum, new tranny (46re built to the max), Lift (8-9 inches), and 35+ size tires. It would be a hog off road!
Old Mar 27, 2008 | 11:24 AM
tntitans21399's Avatar
tntitans21399
Default RE: 42re
I really like my Dakota, good size and enough room and handles about what I can give it. Ofcourse 4WD would be great but I really wouldn't use it that much. I was curious about the V6 to V8 conversion. Is it pretty simple to upgrade to the V8 or is their a lot of labor and trouble in the conversion?
Old Mar 27, 2008 | 03:17 PM
wink2873's Avatar
wink2873
Default RE: 42re
yea, the 8.25 is pretty strong. alot of people get into trouble with them when they are pushing enough power to need slicks at the track. I've seen a couple videos where when the rear just completely blows at launch. When you're putting down alot of power and are able to get it to the ground without slipping, you will need a better rear but i wouldnt worry about it. I have also heard about alot of 9.25 rears blowing too, in my opinion the 8.25 is just as strong.
Old Mar 27, 2008 | 04:42 PM
varsis's Avatar
varsis
Default RE: 42re
Yea, I hope I sell this truck. Just want to get a fullsize. They aren't too bad, and are probably the same on gas just better for power. But if I do get the v8 in there. I will probably upgrade everything eventually I was more looking for torque numbers on the transmission.
