What do u think?
Old Apr 11, 2008 | 08:28 PM
  #21
wink2873's Avatar
wink2873
Default RE: What do u think?
there is no 5.9 hemi so im assuming you mean the 5.7 hemi. I can tell you right now the frame rails on the dak arent wide enough for any hemi to fit and i would think you would have to buy custom motor mounts. There may be enough room long ways if you ditch the clutch fan and shroud in favor of a very powerful electric fan.
Old Apr 11, 2008 | 08:33 PM
  #22
Spike300's Avatar
Spike300
yea i did meanthe 5.7 opps. yea im gonna do the electric fan mod for sure. What is the measurement of thr motor mounts for the two hemis and what is it on the 5.2 magnum
Old Apr 11, 2008 | 11:22 PM
  #23
00DakR/T's Avatar
00DakR/T
I would definately go for the 5.7 or 6.1 If the stuff at Powerported.com isn't enough for ya I don't know what would be
Old Apr 11, 2008 | 11:55 PM
  #24
imnothot02's Avatar
imnothot02
cummins nuff said...
Old Apr 12, 2008 | 12:19 AM
  #25
varsis's Avatar
varsis
the hemi will fit. I talk to a guy who does have a hemi only the 5.7 but he did a cam swap running a cam..
But thats it. Lots of wiring work...
Old Apr 12, 2008 | 12:26 AM
  #26
Spike300's Avatar
Spike300
my friend who is a mechanic at a dodge dealership willhelp with the wiring. Do you think i should start with a bare block and go from there or get a used engine and upgrade that?
Old Apr 12, 2008 | 03:29 AM
  #27
varsis's Avatar
varsis
ORIGINAL: Spike300
It all depends. I would start with a 6.1L block, and build it up. But I would still suggest buying a 4.7 Dakota that way most of it will mate, but if you go with the 426, the 727 will even bolt up-to your current engine. While your getting your engine rebuilt you can be doing axles and transmission. Still Drive when ready drop the engine in.
Old Apr 12, 2008 | 01:23 PM
  #28
scandal669's Avatar
scandal669
wow! if you have the money, it sure would be a one of a kind. if i had 16k to spend on my truck id probably get a crate 360. they have near 400hp and cost less than half of a 426, plus a 426 weighs a ton, the power to weight ratio is better on the crate 360, plus you wouldnt have to beef up the suspension to handle all that or do a ton of mods to make a 426 fit. with the leftover money, id hook up a built tranny and rearend and still have money leftover to do cosmetic stuff...but thats just me.
Old Apr 13, 2008 | 07:18 PM
  #29
Spike300's Avatar
Spike300
i can aford a 5.7 but not a nother truck stillmaking payments for 3 years yet, but iv decided to go with the 5.7 for sure
Old Apr 14, 2008 | 12:37 AM
  #30
crateampsrock's Avatar
crateampsrock
Screw the hemi, drop a Turbo charged Cummins in, that'll wake it up.
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
