Custom Air Intake Idea?
Old May 30, 2008 | 07:01 PM
xtimgx's Avatar
xtimgx
Default Custom Air Intake Idea?
Hey guys. Had an idea of making a custom air intake and seeing if it would work. On the fender near the hood, I was thinking of cutting holes in on each side of the truck. Using angled air vents to direct air into the engine bay with small K&N rectangular or circular filters depending on the hole into the truck. Having two air pipes going into one central connector and going into the intake. Providing I'm not sucking water, make it look nice and it flows well, the truck should get extra air to the intake if I'm thinking correctly. Hopefully my post was coherent enough to describe my idea. If it needs more description, I can throw something together in Photoshop real quick. Thanks in advance and hoping to hear what you think.
-Tim
Old May 30, 2008 | 08:02 PM
wink2873's Avatar
wink2873
Default RE: Custom Air Intake Idea?
it wont do you any good and you'll look stupid with holes in your truck.
Old May 30, 2008 | 09:57 PM
batman13's Avatar
batman13
ram air hood would work better, and holes in the side would look really bad
and coming from the guy who drove for 2 weeks with no bed. i'd know
Old May 30, 2008 | 10:16 PM
wink2873's Avatar
wink2873
lmao, thats how we roll in ohio.
Old May 30, 2008 | 10:24 PM
batman13's Avatar
batman13
werd. 8" neons and everything lol
i finally got new filters,
king of low-cost
Old May 30, 2008 | 11:26 PM
marchant's Avatar
marchant
check the sig. pics
Old May 31, 2008 | 08:17 AM
batman13's Avatar
batman13
PVC will eventually damage your engine.
as it gets hot, it releases chlorine, which is not a good chemical in engines
Old May 31, 2008 | 10:44 AM
scandal669's Avatar
scandal669
ORIGINAL: xtimgx
-Tim
if you feel you need to be cutting holes, id do an AAR cudastyle hood scoop that is functional. i agree with others here that scoops on the fender would not look good at all
Old May 31, 2008 | 10:48 AM
scandal669's Avatar
scandal669
ORIGINAL: batman13
never heard about chlorine. im betting its such a minimal amount that it isnt truly going to hurt anything. many people have used PVC for stuff like this. although, most "home made" writeups i have seen say to use ABS tubing or exhaust pipe...
Old May 31, 2008 | 11:47 AM
batman13's Avatar
batman13
PVC is polyvinylchloride, heat allows the chlorine to separate, it dosnt do much right off but in the long run it will affect intake and exaust sensors, poor fuel burn, engines need oxygen to run well, they are not meant to burn chorine, since it isnt a major element found in the air
