opinions please
Old Sep 9, 2008 | 09:35 PM
batman13's Avatar
batman13
Default opinions please
ok, heres the nature of the matter
i have 2, 5 gallon air tanks,
they are going to be mounted in the toolbox behind my cab,
the only other things set for the box, is 8 valves and wiring/airlines to the valves,
the compressors are mounted up under the truck and i like them there,
i will run a single line from the 2 comps into the box to a tee to the tanks, so both tanks act as 1
so i got to thinking of tank locations within the box, heres the options.
basic,however air lines may get messy with port locations
still simple, connect tanks in the middle with a tee and connect both compressors and gauge line (to gauge in cab)
but limited space around ports, would require 90* elbows on all ports. but keeps lines near front of truck.
little different, but i get plenty of room between the ports and walls of box.
however it does take up a little more space in box
same thing but different angle
i just wanna get some input other than the little voices in me head
Old Sep 9, 2008 | 09:38 PM
rtdakota2001's Avatar
rtdakota2001
i like #2.
saves room for a few small other things you may want to throw in there.
Old Sep 9, 2008 | 09:54 PM
TheePlaymaker's Avatar
TheePlaymaker
option 1 but maybe move them to one side or the other then you have a good amount of space on the side where the tanks aren't
Old Sep 9, 2008 | 11:06 PM
f0x672's Avatar
f0x672
Originally Posted by rtdakota2001
i like #2.
+1, thats what i would do and i would put the compressor in the box as well, but that's just personal preference
Old Sep 9, 2008 | 11:29 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
yea i was thinking the same thing, if you have room for the compressor in the box that is what iw ould do also and i like #1 best w/ a compressor on each side maybe
Old Sep 10, 2008 | 04:53 PM
batman13's Avatar
batman13
well ok, the compressors need airflow since viairs run hot and can burn up, which would be expensive, im looking at compressor locations here now, i am gonna go with the second option for the tanks,
hopefully i'll be able to get train horns pretty soon so i can use all this junk lol
Old Sep 10, 2008 | 05:11 PM
rtdakota2001
be careful i know someone that got a pretty healthy size ticket for blowing a train horn. it's illegal.
Old Sep 10, 2008 | 05:29 PM
batman13's Avatar
batman13
i know, its not gonna replace my stocker, but it will be fun nonetheless
Old Sep 10, 2008 | 06:38 PM
jonnymagnum's Avatar
jonnymagnum
I would go with #2
Old Sep 10, 2008 | 06:55 PM
f0x672's Avatar
f0x672
most likely jam the compressors on the outside of the frame rail, that should be a decent amount of air flowing by in that area. where are you thinking of putting the train horns?
