crazy suspension idea
Old Sep 13, 2008 | 09:12 AM
batman13's Avatar
batman13
IMPO, the parallel would be your best bet, not as expensive, and you dont really need the suspension travel the tri-4 gives.
the big thing to know, when you do this, you have to do it with your bed removed, and set your ride height before you do any measuring, easiest way is to support your frame in the rear with a jack, and once you unbolt the leafs, lower the frame until you have the height you want, tack weld a bar from the frame to the axle to keep it at the proper height, then you can measure mount, tack weld.after you tck, double check everything, mount the coils, tighten any adjustable bars, and cut the bar off the frame and axle, then you can re-check everything, before you do the final welding
Old Sep 13, 2008 | 12:48 PM
rtdakota2001's Avatar
rtdakota2001
ow....my brain
Old Sep 13, 2008 | 01:30 PM
batman13's Avatar
batman13
sorry,
Old Sep 13, 2008 | 04:39 PM
rtdakota2001
where an you find that first setup. i found a couple but they all come with the whole airbag system which means its gonna cost like $1,100. i'm just lookin for the links and the panhard and ill find me some coilovers on my own later.
Old Sep 13, 2008 | 05:48 PM
batman13's Avatar
batman13
http://www.suicidedoors.com/4-link-k...lel-4-link-kit
http://www.suicidedoors.com/4-link-k...anhard-bar-kit
the first is the parallel bars and the second is a panhard kit,
http://www.suicidedoors.com/shock-re...ck-mounts-pair
and here is a shock mount bracket, if im not mistaken coil-overs mount the same as shocks do.
check the site out they do have stuff that may be interesting for ya
also i know a guy who did a shockwave kit on his quad cab 5.9, looks killer, i'll find pics for ya
Old Sep 13, 2008 | 07:13 PM
moe7404's Avatar
moe7404
moe in wichita ks
why do you think the dodge and plymouth super stocks whipped up so bad on chevys and fords in the 60s? LEAF SPRINGS
Old Sep 13, 2008 | 08:26 PM
batman13's Avatar
batman13
leafs suck when you really wanna race, drag or track
a 4 link with progressive coil-overs will put the power to the ground much more effectively. and give a smoother ride.
the best racecars these days all run coils, period,
leafs can actually twist under high power applications, causing wheelhop and axlewrap,
thats only if they don't snap under the pressure
the 60's was a long time ago
Old Sep 14, 2008 | 10:29 AM
DRO318's Avatar
DRO318
would that same setup work for durangos as well? I wanted to go bags in the front but it seemed stupid to only have the front on bags
Old Sep 14, 2008 | 11:42 AM
batman13's Avatar
batman13
yup will work on the 'rangos as well,
if you guys want the ultimate in suspension performance, its proven that AIR is the absolute best, you dont have to lay out like i want to, but if you run shockwaves, you will be able to change your height and stiffness instantly from the drivers seat
Old Sep 14, 2008 | 12:39 PM
moe7404's Avatar
moe7404
Default leaf springs
moe in wichita ks
i do have to admit that i dont have much experince at drag racing, but i have spent a lot of time around drag racing.
yes i know that 4 link works good. what iam trying to say is both have there place . but the hemi cudas are going mid 8s, with LEAF SPRINGS. just cause some people cant get leafs to work doesnt mean it cant work. you just have to do it the way chrysler lines out in there books. i think that some people are stuck in the " the factory cant do anything right, so ill do it better" rut. i knew some guys that raced maxi-wedge cars. two of them thought that cause holey made a biger size carb than mopar put on the maxi-wedge i should go faster. guess what .4 slower. my dad used to say "dont out trick yourself"
