Few questions bout a 3.9 w/ a V8 TB
Old Nov 24, 2008 | 05:59 PM
RoaminGnome's Avatar
RoaminGnome
Exclamation Few questions bout a 3.9 w/ a V8 TB
Ok so I am buying what I need to do this swap and just need to be sure I get everything. Are the 3 sensors the same from the 3.9 to the 5.9? Im pretty sure the TB gasket is the same too but just wanna hear it again
Other than the throttle cable from a V8 is there anything else I need to do or buy to make this work?
OH and what do I torque the TB to? My Haynes manual says 200 in/lbs, yes INCH POUNDS! How wrong is that? My torque wrench and all that Ive ever seen only go in ft/lbs. So I THINK that it converts to 16.5 ft/lbs but is it different for the V8 or am I just wrong in general?
Thanks everyone
Old Nov 24, 2008 | 06:05 PM
varsis's Avatar
varsis
nope.
200 in/lbs is 16.6 ft/lbs. So I a regular ol torque wrench will be fine. V8 is the same but bigger bore. No new throttle body sensors, they are the same too.
Old Nov 24, 2008 | 06:22 PM
RoaminGnome
Fantastic! But I do need the V8 throttle cable right? And its just a bolt on swap right?
Just being safe and asking the stupid questions to avoid problems.
Old Nov 24, 2008 | 06:27 PM
varsis's Avatar
varsis
yea all you need is a cable. nothing else.
Old Nov 24, 2008 | 06:31 PM
RoaminGnome
Awesome thanks
Old Nov 24, 2008 | 07:35 PM
wink2873's Avatar
wink2873
the gasket's the same too
Old Nov 25, 2008 | 04:54 PM
RoaminGnome
Ok so Ive seen that you need a new cable OR an adapter? Anyone know anything bout this? I think it would be easier than swapping the throttle cable, Ive never had to replace this cable so maybe its easier than I think.
Oh and is there a place I can get the screws that hold the sensors in? I took out one sensor and cleaned it up a bit.The screws on one of the other sensors didnt want to loosen and I didnt want to snap them so I left it. Just thought Id think ahead and grab extras just in case
Old Nov 26, 2008 | 11:32 AM
Brymac76's Avatar
Brymac76
The cable is easy to replace.....it "can" be a little tricky feeding it through the fire wall behind the gas peddal......but not always.
not sure about gettn new screws...sorry
Old Nov 26, 2008 | 04:57 PM
RoaminGnome
S'ok good to know that the throttle cable shouldnt be a nightmare tho
Thanks everyone
