Lower ball joint question
Old Jan 18, 2009 | 12:04 AM
asmodeus289's Avatar
asmodeus289
Default Lower ball joint question
Does anyone know the torque setting for the lower ball joint to control arm mounting bolts?
BTW, it a 2WD.
Thanks
Old Jan 18, 2009 | 12:12 AM
f0x672's Avatar
f0x672
says 94 foot pounds in the manual but i believe that's the ball stud to the steering knuckle.
Old Jan 18, 2009 | 12:16 AM
dodgerules86's Avatar
dodgerules86
You mean lower ball joint to steering knuckle bolt. (Because the ball joint is pressed into the control arm)
Anyways, it's 135ft. lbs. for 4WD, and 94 ft. lbs. for 2WD.
Old Jan 18, 2009 | 02:12 PM
asmodeus289
I know they are pressed in. I'm replacing them today with some bolt in ones. And I can't find anywere torgue specs for those bolts.
Old Jan 18, 2009 | 02:53 PM
dodgerules86
Please provide some pics of these.
Old Jan 18, 2009 | 11:08 PM
asmodeus289
Here you go.
File Type: jpg
Old Jan 19, 2009 | 01:45 AM
dodgerules86
That is very interesting to me.
Are there actually holes in the control arm for the bolts to go through, or did you have to drill them? (I haven't worked on a Gen 2 Dakota)
Old Jan 19, 2009 | 10:12 AM
asmodeus289
I had to cut the tops of the rivets with a torch and air chisel. Then drill into them and punch them out.
Old Jan 19, 2009 | 05:46 PM
dodgerules86
Oh yea, that's right, the crappy rivet-in ball joints. One of them things those geniuses at Chrysler came up with. I really congratulate them on those, and the greaseless ball joints as well.
