Need some help
Old Mar 7, 2009 | 11:52 PM
wink2873's Avatar
wink2873
oh, i didnt realize you were getting absolutely nothing when you turned the key. in that case, my money's on the starter. field test it on a known good power source.
Old Mar 8, 2009 | 12:40 AM
big.bryant's Avatar
big.bryant
another thing... although its probably the starter, take the terminals off and clean them up a little bit and maybe that will help... if it doesn't then its the starter probably but cleaning the terminals can't hurt...
Old Mar 8, 2009 | 12:48 AM
GaryC's Avatar
GaryC
If you can get to the starter, give it a good smack with something ( not a BFG) what happened is the BENDIX is not energizing, the starter motor is spinning but the bendix is not pushung the gear forward into the path of the flywheel. trying to start it with a low charge will create an arc spot on the bendix. Sometimes you can jiggle it to a clean spot by hitting it and the inner spring tension will let it work.
This will just get you home though, you will need to change the starter because eventually, it will land on that dead spot and you will be stuck again.
Old Mar 8, 2009 | 01:07 AM
wink2873's Avatar
wink2873
thats true, sometimes you can wack the starter with a rubber mallet or something and it'll work for a while. its worth a try anyway.
Old Mar 8, 2009 | 09:26 AM
bpark8824's Avatar
bpark8824
Ok thanks a ton guys I look at it today... btw whats a having a starter changed run people these days, $2-300
Old Mar 8, 2009 | 03:17 PM
GaryC's Avatar
GaryC
if it is not under warranty, check autozone and buy one with the lifetime warranty, or, do the work yourself if you have some skill, or, pay a buddy with a 30pack!
Old Mar 8, 2009 | 11:08 PM
bpark8824's Avatar
bpark8824
haha yeah I do it on my dak, but she has a 4 banger in there. Those stupid sideways engines lol. Its in the way back and trying to do it in the school parking lot wouldn't be fun.
Gary you seem new to the site but you must know a ton, in the past couple weeks anyone with a question you seem to know the answer. Were you a mechanic or something? Welcome to the forum you're already a ton of help. Thanks!
Old Mar 30, 2011 | 03:33 PM
jconti8190's Avatar
jconti8190
i no im a little late on this one but for future reference check the ignition fuse. i had the same problem with my truck. did all these tests to find out it was a little friggin 50 cent fuse haha
Old Mar 30, 2011 | 09:55 PM
frydaddy82's Avatar
frydaddy82
hay man you might awant to try and turn the moto by hand just a lull bit and it might alighn the gears. like gary said it could be the bendix not thrownin the gear out.jack the car up and start tapn on it while she trys to start it. worth a shot any ways! good luck
Old Apr 13, 2011 | 10:15 AM
ptfclerk's Avatar
ptfclerk
I believe your selonoid has gone out on your starter. Pull it and have it tested. Do battery at same time (after fully charged) as you'll need to remove neg cable to pull starter anyway
