Whole lotta stuff...
Old 03-10-2009, 03:42 AM
Spike300's Avatar
Spike300
Spike300 is offline
Check EBC had theyre green pads worked great with stock rotors. Got mine off ebay for $40
  #32
Old 03-10-2009, 05:04 AM
User's Avatar
User
User is offline
I use the EBC Rotors and Green Stuff Pads... they are NOISSSSSIE **** HELLLLl!!!!!!!!
God its annoying.. i have to slam the brakes about 1 time a week to get the noisy *** sqeeeel to go away.
300$ for the the front 2 and they sound like they are a set of 20$ brake job... although they do stop on a dime..
also my Rotors already have small stress cracks in them...
Im going to upgrade to Vipers sooner or later... ill add that to my list of mods.
Attachment 3031
  #33
Old 03-10-2009, 07:54 AM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
bryant, if you can find an 03/04 dak in the junkyard with disc breaks in the rear id do that for the swap, its already configured for yout truck (basically) just unbolt everything ya need from the junker, and bolt it back up to your truck this solves the parking break issue and will give you ALL the parts that you could need for the swap.
but FYI, my dads 03 has 4 wheel discs on it and i dont like the way they stop, the power increses if you hold the break pedal steady, whereas my truck it grabs rigth away if your not careful about it(mine has rear drums)
  #34
Old 03-10-2009, 10:35 AM
magnethead's Avatar
magnethead
magnethead is offline
ah, the old drum/disc issue.
as per I understand it, drums have long been theorized as being better than discs because there is more friction surface area, which should help stopping distance. Discs are lighter and have a better cooling ability for heavy use.
So theorietically, a combination truck should stop better than a 4 wheel disc under ideal conditions...but those never exist.
  #35
Old 03-10-2009, 01:42 PM
Spike300's Avatar
Spike300
Spike300 is offline
My ebc made noise bou the first 2 weeks then went away
  #36
Old 03-10-2009, 05:31 PM
big.bryant's Avatar
big.bryant
big.bryant is offline
for now i will jsut keep the rears drums and plan on ordering those front discs and pads here in the next couple of days...
  #37
Old 03-12-2009, 01:29 PM
yellowjacket99's Avatar
yellowjacket99
yellowjacket99 is offline
I've got the Baer Decela rotors with the EBC green pads. Been very happy with them for over a year. Don't seem to be stopping as good now though, so I need to check that out.
  #38
Old 03-12-2009, 05:00 PM
big.bryant's Avatar
big.bryant
i found some other ones, which i will probably get:
http://stores.brakeplanet.com/Items/...20Brake%20Pads
  #39
Old 03-12-2009, 11:21 PM
bpark8824's Avatar
bpark8824
bpark8824 is offline
That looks like a pretty good deal
How many miles does your truck have on it. Just wondering since you said you were doing the clutch. Does it really need to be done or are you doing it just to do it?
  #40
Old 03-12-2009, 11:34 PM
big.bryant's Avatar
big.bryant
i have 94300 or so, and i think it needs it and also i kinda want to replace it just to have that extra piece of mind. I plan on building it up over the next year or so and could use a stage 2 to handle that extra oomph so its kinda both.
Quick Reply: Whole lotta stuff...
Top
Follow Us
