long tubes make me want to punch babies.
#21
and i told you so....
did you have to cut those stupid little bolts coming out of the firewall? I did with my PPhs
and i dont see how the canister is in the way, unless you mean you cant slide the header into place cuz its in the way
#23
yes, that's exactly what i mean. i had a little freak out today while working on this god forsaken project and accidentally put a tiny ding in one of the primaries. oops, i have anger issues..... also, the steering shaft is haunting me, i have no idea how that's gonna go back in, i think i'm going to have to unbolt it from either side and just thread it through the primaries and bolt it back up. fock my life...
#24
thats how i see it... 345lbs stock all made down low.. and you want more.. pfft...
#26
#27
yea im the same way, when i start working on something the garage becomes off limits unless you have a death wish, if something doesnt work wrenchs start flying
and i cant fine the entire list , i saw it somewhere, just cant remeber where)
but remember that the wrench you just threw across the garage (driveway, w/e you happen to have) is the one that you will need next
#28
#29
yep and then your to pissed off to go get it so you go with a metric version, round off the nut and then things are even worse....
#30
well, yea, buyta t that point ya go looking for the sawzall cut the hear off the bolt, drill it, remove it, and buy a new bolt, that is IF you can get the sawzall in there, otherwise you try to grind new flats onto it in the right size so that the next socket smaller will fit on it w/o rounding it off again
