Engine oil dipstick
Old Apr 2, 2009 | 10:17 PM
primus454's Avatar
primus454
Default Engine oil dipstick
So after an oil change (done at home, so it should be fine) in my 318, the dipstick is showing that it is at least a quart over, but I added the 5.0 quarts that my Haynes manual recommends.
Old Apr 3, 2009 | 12:38 AM
primus454's Avatar
primus454
If anyone would be so kind as to match up codes on the dipstick, I have one that reads 53020925
Old Apr 3, 2009 | 01:57 AM
95_318SLT's Avatar
95_318SLT
Did you change the filter also, cause that will hold about a quart.
Old Apr 3, 2009 | 04:04 PM
primus454's Avatar
primus454
Yessir. Most certainly did.
Old Apr 3, 2009 | 05:19 PM
rtdakota2001's Avatar
rtdakota2001
did you fill up the filter when you changed it or did you install it dry?
Old Apr 3, 2009 | 07:53 PM
primus454's Avatar
primus454
If you mean just screwing in the filter, then dry it is.
Old Apr 3, 2009 | 09:03 PM
rtdakota2001
well then thats where you 1/2 - 1 qt disappeared to i would guess.
Old Apr 3, 2009 | 09:50 PM
varsis's Avatar
varsis
did you run it then check the level? for like 30 seconds about?
Old Apr 3, 2009 | 10:06 PM
99dakota318's Avatar
99dakota318
I put 5 quarts in mine and it always shows a quart over...why? I have no clue.
Old Apr 4, 2009 | 01:13 AM
dodgerules86's Avatar
dodgerules86
That part number is correct according to the 1997 and 1998.
For whatever reason, 1999 shows part number 53021354 for 2WD, and 53021355 for 4WD. (In 2000, they changed to these part numbers on the 5.9L as well, but in 1999 and previous, it used 53020925)
Maybe check and make sure the metal part of the dipstick is fully seated in the part you actually pull on. It's been a while since I've checked the oil in my truck (been down for repairs), so I'm not sure if the metal part could "pull out."
