Fluid Capacities
Old May 28, 2015 | 08:19 PM
Robertwav1's Avatar
Robertwav1
Originally Posted by Blacknights
The fuel tank sizes are true for the 4-cylinder and 6 cylinder (respectively). But my 4.7 has a 24 gallon tank and I'm pretty sure all the V8s had 24 gallon tanks.
To add to this when I was doing my fuel pump, the part# is stamped on the bottom of the gas tank. You can look it up anywhere and it tells you the capacity.
Old Jun 24, 2015 | 12:18 AM
04DakAz's Avatar
04DakAz
Originally Posted by bogie107
No 3.7L. Is the 3.9 the close to the 3.7?
I just recently dropped my 42rle/3.7 pan for a new filter and Replace a leaking drain plug. It took me 5.5 Quarts
Old Sep 6, 2017 | 11:56 AM
Raptoor4561's Avatar
Raptoor4561
i see that the 3.7l isnt included, do you happen to know the quantities on it? the 2004 model dakota didnt have the 3.9l v6, they came with the newer 3.7l
thanks,
rap
Old Apr 17, 2018 | 02:57 AM
Steve M's Avatar
Steve M
Just an FYI, my Dodge Dakota is 4x4 and has a 15 gallon tank and the engine is a 5.2L V8 which takes 6 qt oil when I do the oil changes.
Old Jan 6, 2022 | 01:03 PM
TheDodgeBoi's Avatar
TheDodgeBoi
What do you guys use for oil in 5 speed manual trans? I have heard so many conflicting opinions on that....
Old Jan 7, 2023 | 08:11 PM
Rustyvan's Avatar
Rustyvan
Cooling System
2.5L : 9.8 qts. (2.45 Gallons)
3.9L : 14.0 qts. (3.5 Gallons)
4.7L : 17.0 qts. (4.25 Gallons)
5.9L : 14.3 qts. (3.575 Gallons)
(5.2L Is most likely close to 14.3 qts)
I just recently replaced my water pump in the 4.7. I replaced hoses and such. This shows about 4 gallons.
Mine seems full at just over 2 gallons. Is just over 2 gallons possibly correct if there is variances in radiator sizes?
Old Jan 7, 2023 | 10:31 PM
That 4 and change gallons is for the ENTIRE cooling system. That includes all the hoses, the heater core, and the engine itself. Make sure you bleed all the air out of the system, and it'll be fine.
Old Mar 24, 2024 | 06:28 PM
mmontaser's Avatar
mmontaser
I really appreciate of fluid list you posted. I was looking for such a list all in one place. Thank you Very Much.
Old Jun 17, 2024 | 04:04 AM
KD2003PA's Avatar
KD2003PA
Default Oil Change with New Filter
My owner's manual says 4 quarts of oil with a new filter. 2003 3.9 V6 .
Old Jun 17, 2024 | 09:11 AM
FOUR????? That doesn't seem right......
