Fluid Capacities
Old Jun 1, 2009 | 07:15 PM
CSCustomCars's Avatar
CSCustomCars
Default Fluid Capacities
Got this list from the dealer of all the fluid capacities for a 2000 Dodge Dakota, but it includes All engines Except the 5.2L, transmissions and both rear ends. Maybe someone can sticky this or put it in the DYI section. Just thought I'd type it up for everyone as there are frequent questions concerning capacities.
Capacities are in Pints, quarts, or gallons. If listed in Pints, I've added the measurement in quarts as well.
Fuel Tank
Standard : 15 Gal.
Optional : 22 Gal.
Engine Oil With Filter Change
2.5L : 4.5 qts.
3.9L : 4.5 qts.
4.7L : 6.0 qts.
5.9L : 5.0 qts
(5.2L is most likely 5.0 qts. as well)
Cooling System
2.5L : 9.8 qts. (2.45 Gallons)
3.9L : 14.0 qts. (3.5 Gallons)
4.7L : 17.0 qts. (4.25 Gallons)
5.9L : 14.3 qts. (3.575 Gallons)
(5.2L Is most likely close to 14.3 qts)
Automatic Transmission
(Dry Fill Capacity - Depending on type and size of internal cooler, length, inside diameter of cooler lines or use of auxiliary cooler, these figures may vary.)
42RE : 19-20 Pints (9.5-10 Qts.)
45RFE : 28 Pints (14 Qts)
46RE : 19-20 Pints (9.5-10 Qts)
Manual Transmission
NV3500 : 4.2 Pints (2.1 Qts)
AX15 : 6.6 Pints (3.3 Qts.)
NV1500HD : 4.7 Pints (2.35 Qts)*
*Include .22 Pints for Friction Modifier
Transfer Case
NP231 : 2.5 Pints (1.25 Qts.)
NP231-HD : 2.5 Pints (1.25 Qts.)
NP242 : 2.5 Pints (1.25 Qts)
Front Axle
Model 194 : 3.0 pints (1.5 Qts.)
Rear Axle
8.25" : 4.4 Pints (2.2 Qts.)
9.25" : 4.8 Pints (2.4 Qts.)
Power Steering
Power Steering fluid capacities are dependent on engine/chassis options as well as steer gear/cooler options. Depending on type and side of internal cooler, length and inside diameter of cooler lines, or use of auxiliary cooler, these capacities may vary.
Old Jun 3, 2009 | 01:08 AM
CSCustomCars
Guess no body cares... Oh well. At least people can search for it now...
Old Jun 3, 2009 | 09:00 AM
bpark8824's Avatar
bpark8824
Nice, thats pretty good information, should be a sticky
Im actually going to print that out and put it in my service manual so now everything is in one spot.
Old Sep 13, 2014 | 05:04 PM
indiglofish61's Avatar
indiglofish61
I just got done draining the trans pan and putting a new gasket on my Dodge Dakota 2000 SLT 3.9L, and it took me 6 Quarts to fill it, everywhere I looked it said it should only take like 4.5 quarts, it is not leaking and it has been running fine, my ? is, Why did it take so many Quarts? anyone!
Old Sep 13, 2014 | 05:47 PM
00DakDan's Avatar
00DakDan
Section Moderator
Consider the threat "stuck."
Thank for the info CCCustomCars
Old Sep 14, 2014 | 10:39 PM
magnethead's Avatar
magnethead
you may have a deep pan. The stock pan is only like 1.5" deep, deeper pans do exist.
Old Sep 15, 2014 | 08:26 AM
indiglofish61
The pan I got is like 3" or so, We did buy it off the car lot. back in 2000.
Old Oct 11, 2014 | 08:22 PM
Blacknights's Avatar
Blacknights
The fuel tank sizes are true for the 4-cylinder and 6 cylinder (respectively). But my 4.7 has a 24 gallon tank and I'm pretty sure all the V8s had 24 gallon tanks.
Old Oct 20, 2014 | 01:28 PM
Thx1138's Avatar
Thx1138
thanks for this reference post. Excellent info.
Some can vary. I just did full tranny service with converter. (98 RT) Put 10 quarts in and it wouldn't register on stick. Took another 3! So this one most have a deeper pan or something with the cooler.
Old May 27, 2015 | 11:39 AM
bogie107's Avatar
bogie107
No 3.7L. Is the 3.9 the close to the 3.7?
