Bank 1 misfires
Bank 1 misfires
I have searched the forum and found the post by Rouler01, but there was no answer to his post. I also have the exact same problem. I have installed new wires, plugs, cap and rotor, coil, crank and cam sensors. I also tested the TPS and it was good. I recently put a new transmission in the truck, so I don't plan on getting rid of it. Any help is greatly appreciated. Also all parts are OEM, I had Bosch when it started acting up. Thanks. Chris J.
I've been trying to fix the same problem,same year, same motor, same misfire codes. I've tried all the suggested repairs and still the same. My next thing to try is replacing the wiring harness. I just wish that when someone fixes this problem they post what they did to fix it.
Good luck and let me know what works.
Yes they are, I did those myself with a real gap tool, not a keychain. .40 is what is written under the hood, and also what the service dept. at the dealership told me when I bought all the tune-up parts. I had found one screw on the cap was broken off, I fixed that and it still has a miss. For it to be just one side, I am begining to think it may be the cat on that side. I'll do a compression test this week-end before I start ripping off the exhaust.
Trending Topics
I took a drive to the Canfield Ohio swap meet 3 1/2 hours each way, 70-75 mph no stops along way, drove at night so no other traffic and checked mileage both ways 22.4 and 22.6 mpg.
Truck was empty, tonneau cover, cold air intake check engine light was on the whole time. misfire 1 3 and 5. My truck runs good at speed but you can feel and hear a misfire when stopped. It wants to stall and has no power to take off.
If your mpg is still great, then it probably isn't a o2 sensor. Your engine coolant temp sensor, and iat sensor also play a roll in how the computer controlls the timing/ fuel mixture. Are you able to feel these misfires @ a stand still, or only on a scanner? What do all of your plugs look like, are they all the same color platform, or are some a softer color than others? What is your idle set @? It might be you need to raise the idle a 100 rpm which can be done with the set screw on the TB.
