46re hangs in seconds gear until 2500
Old Sep 21, 2009 | 05:24 PM
magnethead's Avatar
magnethead
that's pretty close to my exact shift points if im not heavy on the throttle. If I am, it carries red line out the back door.
Old Sep 21, 2009 | 05:28 PM
bpark8824's Avatar
bpark8824
It really shouldn't shift that high under normal driving conditions unless you adjusted it...
Old Sep 22, 2009 | 02:55 PM
magnethead's Avatar
magnethead
yea, it's adjusted. It hangs in neutral for a short bit (and hits the limiter with enough throttle) before second gear if i move the cable any further forward. Right now, the nozzle's tip is lined up with the clip housing.
Old Sep 22, 2009 | 09:37 PM
bpark8824's Avatar
bpark8824
Oh ok, that makes sense then. I didn't think it should be shifting like that with the stock settings...
Old Sep 23, 2009 | 10:17 AM
davidonmars's Avatar
davidonmars
if I floor it it shifts fine with no hanging
