46re hangs in seconds gear until 2500
Old Sep 17, 2009 | 11:13 AM
davidonmars's Avatar
davidonmars
Default 46re hangs in seconds gear until 2500
I got a 5.9 with a 46 re in my dakota. The tranny hangs in second gear until 2500 rpm regardless if i baby it or accelerate quickly until then. It will shift before 2500 if i take my foot off the gas for a second. Any ideas? It shifts fine though at 2500
Old Sep 17, 2009 | 11:59 AM
1999R/T's Avatar
1999R/T
Id get used to that. Mine done the exact same thing, it has something to do with the way that tranny's set about taking of or something. Only fix i know of, possibly a shift kit would fix it depending on how its set up. Or change it to a stick like i did!
Old Sep 17, 2009 | 04:43 PM
varsis's Avatar
varsis
try adjusting the tv cable.
Old Sep 17, 2009 | 07:56 PM
davidonmars
d the tv cable and it just brought all the shifts up including second
Old Sep 17, 2009 | 10:03 PM
magnethead's Avatar
magnethead
move the TV cable clip closer to the linkage in 1/8" increments, it will lower the line pressure. I have mine pulled back because i prefer the high shift points.
Old Sep 18, 2009 | 09:47 AM
dandragonrage's Avatar
dandragonrage
Poor shifting can also be the governor pressure sensor (or solenoid) inside of the transmission. Replacing those really helped my truck shift better. I think I paid a bit north of $100 for all the parts and it took about 90 minutes of my time (and it was my first time doing transmission work other than a filter change).
You've started with some of the simpler things, but another simple thing: Have you checked your transmission fluid?
If you need fluid (you will obviously need it if you change those parts), make sure to use ATF+4. Some aftermarket brands (IIRC Castrol and Valvoline) have a license to market it so I got Castrol +4 from Autozone when I did mine.
Old Sep 18, 2009 | 03:45 PM
magnethead's Avatar
magnethead
I just realised you said 2500 , not 5200 (what i saw). That's a normal shiftpoint i think...before i did my TV cable that's where it shifted for 2nd, and dad's hemi shifts all gears in the 2-3000 range.
Old Sep 18, 2009 | 05:33 PM
bpark8824's Avatar
bpark8824
When I had a 3.9/42re it shifted a lot lower than that, but then evntually it started doing that. It seems like a common occurance on dodge trannys. They weren't/aren't the worlds best trannys.
Old Sep 21, 2009 | 09:19 AM
davidonmars
I dropped the pan and put a new filter and refilled with ATF+4 check the level with truck idling in neutral hot and the level is fine. Tv adjustment is fine also/ This is really pissing me off...
Old Sep 21, 2009 | 10:15 AM
davidonmars
My first gear shifts at 1800 second 2300-2700 and the rest are fine
