No brake lights, hazard or turn signals 2003 Dakota
Old Oct 23, 2009 | 05:03 PM
FHScorpion's Avatar
FHScorpion
Default No brake lights, hazard or turn signals 2003 Dakota
2003 Dakota quad cab that has no turn signal, hazards, or brake lights. Checked a number of things, but narrowing to replacing the multifunction switch, but would it effect brake lights? Could not find any relays...are there any, any would they effect brakes?
Before replacing, any other suggestions, and can multifunction switch be checked? Fuses at end of dash appear fine.
Problem started when pulling a rental trailer. LIghts checked out ahead of towing but failed something it the tow... Any help would be appreciated.
Old Oct 23, 2009 | 05:46 PM
magnethead's Avatar
magnethead
my obvious guess would be blown bulbs or fuses due to a short in the trailer wiring.
Old Oct 23, 2009 | 05:52 PM
wink2873's Avatar
wink2873
it couldve fried your central timer module
Old Oct 23, 2009 | 06:31 PM
FHScorpion's Avatar
FHScorpion
FYI...my ODB II code reader shows no faults (and bulbs do look good).
Old Oct 23, 2009 | 06:36 PM
FHScorpion's Avatar
FHScorpion
...another thing, everything else electrically works fine (cruise, windows, wipers, overhead readouts, etc.). Only the brake and turn signals are inop.
Old Oct 23, 2009 | 07:32 PM
Billiam's Avatar
Billiam
Check both fuse placed. Drivers side dash and under hood.
Old Oct 23, 2009 | 09:11 PM
JayJayEl's Avatar
JayJayEl
Make sure there's nothing wrong at the wiring adapter for the trailer, too... I was having issues and that's where I found a short.
Old Oct 24, 2009 | 06:44 PM
FHScorpion's Avatar
FHScorpion
Checked a number of things, but I'm suspecting the 'combination flasher'. Its' brake output is 0VDC so it seems dead. However, the odd thing is the A1 pin which is supposed to be 'Fused B(+)' is only 3VDC, but I would have guessed it to be 12VDC. Or, it may be the result of a bad 'combination flasher'?
Checked out the 'multi-function switch' and it was fine.
File Type: jpg
