2002 Dakota Quad Cab 4.7
The POR-15 isn't hard, of course easier with a lift, but what isn't?
As long as you can get yourself under there enough to scrape off the loose rust and get a paint brush in there to paint it on you should be fine. THe hardest part I think will be getting the top of the frame, but since you have a body lift on it you should have 3" in there to get a wire brush in and a paint brush.
https://dodgeforum.com/forum/1st-gen...-por-15-a.html
I have heard some people think it is difficult to work with but I didn't find that at all. Messy yes, if you get it on the concrete or your hands it isn't coming off.
I did a quick write up on it when I painted my engine.
As long as you can get yourself under there enough to scrape off the loose rust and get a paint brush in there to paint it on you should be fine. THe hardest part I think will be getting the top of the frame, but since you have a body lift on it you should have 3" in there to get a wire brush in and a paint brush. https://dodgeforum.com/forum/1st-gen...-por-15-a.html
That, my friend, is a good question. Slightly off topic but ITS 32 DEGREES right now in the SUNSHINE STATE!! WTF!!!
Anyway, I don't think its originally a florida car, I bought it like 5 months ago.
For the shocks, I jsut changed mine and you dont even have to remove the tires. The front ones are uber easy and the rear ones just require a bit of elbow grease.. once you get tehm off, make sure you put Kopperkote on the bolts before you put them back in so its better for next time
