tires again
Old Apr 23, 2005 | 02:54 PM
914dakota's Avatar
914dakota
Default tires again
Will 31x10.50 tires on 15x7 wheels for a 97 Club cab 4x4 stock supension fit w/o rubbing?
Old Apr 24, 2005 | 01:29 AM
914dakota's Avatar
914dakota
Default RE: tires again
Hey guys I need an answer. Need to buy them tomorrow.
Old Apr 24, 2005 | 05:01 AM
hoobasta4's Avatar
hoobasta4
I have a 2000 Dakota Sport 4x4 ext. cab and I have 31" tires and no rubbing at all
so I dont see why they wouldn't fit?!
hooby
Old Apr 24, 2005 | 01:51 PM
914dakota's Avatar
914dakota
Do you have the 15x7 or 15x8 rims? A 15x7 will give a slightly higher profile. Thats my worry.
Old Apr 24, 2005 | 05:48 PM
hoobasta4's Avatar
hoobasta4
yeh I have the 15x7 and my truck is somewhat higher up than most daks.. because its the sport edition
hooby
Old Apr 24, 2005 | 05:56 PM
cmdak's Avatar
cmdak
i put 31x10.50R15 on my 98. it originally had 235x75R15 and i used the stock 7" rims. they only rub a little on the frame when turned lock-to-lock but you can't feel it at all. in fact, the only way i knew they rubbed at all was when i crawled under the truck to grease it and i saw a small area on each frame rail where there wasn't any dirt! the frame edges are smooth and rounded and didn't damage the tires. if you remember, just don't turn the steering tight lock-to lock. you shouldn't do that anyway because it isn't good for the power steering pump. i guess the 8" rims have different backspacing and that's why they use the small fender flares to cover the little bit of the tire that sticks out. the 7" rims keep the tires even with the fenders and don't require flares. just remember that your speedometer is going to be off a little bit due to the increased overall diameter. -- good luck
Old Apr 24, 2005 | 07:06 PM
Flywheel's Avatar
Flywheel
I dont think that sports sit up higher than SLT's. I have a 00 Sport and it seems to sit at the same ride height as the SLT.
Old Apr 24, 2005 | 08:16 PM
914dakota's Avatar
914dakota
They are on but I couldnt get it aligned because the R hub bearing was toast. I'm hoping the place I bought it from will take care of it since it supposedly passed inspection at the end of FEB. Yeah right!
Old Apr 25, 2005 | 04:54 AM
hoobasta4's Avatar
hoobasta4
flywheel
some do and some don't. get what I mean? some sports are lower to the ground (mainly the v6's) and same with some of the SLT's. I didn't know if he had an SLT that was up higher or not, thats all I meant.
hooby
Old Apr 25, 2005 | 11:00 PM
Flywheel's Avatar
Flywheel
Hooby, I know what u mean now, sorry to sound like an ***.
