Shock Help?
I Just installed a 2-3 Inch Torsion Keys, and 2 Inch blocks in the rear. The Ride is a bit stiffer, and I found out that I was maxing out the suspension during normal driving. So my guess is that I need new shocks, and I need some help figuring out what I need exactly. Can you give me some suggestions on what I need? Its a 2004 4WD 4.7L SportPlus Dakota. Thanks
For lift shocks, I would suggest go to www.google.com and spend some time checking out some shock websites. Like Gabriel or Belstine or any of them.
I just went and checked mine are ruff country shocks. http://www.roughcountry.com/shocks_dodge.html it says 97-03 so I'm not sure if it'll fit an 04
Trending Topics
Both links are in the FAQ in this section, along with more lift ideas.
1997 - 2004 Dodge Dakota 2-3" lift Front shocks
1997 - 2004 Dodge Dakota 2-3" lift Rear shocks
Dodgeforum members get a 5% discount on any order through us, just use the discount code Dodge5 at checkout
