Testing: Gas Mileage
Old Feb 27, 2010 | 05:31 PM
MadisonDakota's Avatar
MadisonDakota
Default Testing: Gas Mileage
I will spend a few bucks of my own money to figure out the gas mileage of the 4.7L engine.
Here is the list of test I will do to try to get an answer.
#'s in parenthesis are my guess for MPG boost/reduction.
  1. clutch fan on vs off +(0-1.0mpg)
  2. 55 vs 65 vs 75 mph (22mpg vs 19mpg vs 18mpg)
  3. e10 vs 100% gas (???)
  4. 35 PSI vs 44 PSI +(1-2mpg)
  5. bed cover on vs off +(0-1mpg)
*I will accept other tests to do from you guys, if I have missed something.
Test truck will be a 2004 Dodge Dakota, 5 speed auto, 2wd.I will maintain 65mph over a 5 mile course. (unless speed is part of the test) And the engine will be fully warmed for each test.
Now here's where it gets tricky, I will be using the overhead computer. This is not 100% accurate, but it will give me the difference in mileage, or at worst, show what helps/hurts.
If you don't like the overhead computers accuracy, i'm sorry, but I trust it for these tests.
Old Feb 28, 2010 | 12:54 PM
beefjerky's Avatar
beefjerky
You should try ethanol free gas also, I'd like to see what that does to your mpg.
Old Feb 28, 2010 | 01:59 PM
dodgeramguy85's Avatar
dodgeramguy85
ethanol free is def better gas station about 10 miles away from me used to have it and with ethanol burns faster. I never checked my mileage when I used it but i could tell i didnt go through a tank as fast.
Old Feb 28, 2010 | 02:39 PM
Rakaric's Avatar
Rakaric
for the mph test....that can vary amongst differential gears. Do you know the ratio of yours?
Old Feb 28, 2010 | 02:59 PM
Josh Abels's Avatar
Josh Abels
He prolly has 3.55s I wish we had ethanol free gas here but it think its state law or something that they all have to have ethanol in them
Old Feb 28, 2010 | 04:19 PM
MadisonDakota
I have the 3.55s.
Old Feb 28, 2010 | 04:20 PM
MadisonDakota
That would be 100% gas.
Old Feb 28, 2010 | 07:06 PM
bpark8824's Avatar
bpark8824
Using the onboard computer is a joke. That thing can be so far off.
Old Feb 28, 2010 | 07:10 PM
thunder98110's Avatar
thunder98110
yup^^ overhead says 13.4 actual was 10
i mean, how lazy are u, just use the odom.
Old Feb 28, 2010 | 07:22 PM
MadisonDakota
Edit:edit
