need help with parts?
Old Mar 30, 2010 | 02:51 PM
dakota Iceland's Avatar
dakota Iceland
Default need help with parts?
I need to know if I can use a steering knuckle from a 1999 dodge durango on a dodge dakota 2000 model . The threads for the brake calipar are finished and these are the only parts available here in Iceland . Otherwise I will have to drill out the threads and insert a nut and weld it stuck . Any suggestions?
Old Mar 30, 2010 | 04:58 PM
2daks's Avatar
2daks
There is a aftermarket bolt from Help(?) that is the same size with self tapping threads. I put mine in years ago and have had it out 3 or 4 times since. It still graps fast. I asked the guy at the parts counter and he knew exactly what I needed at the time. Must be a common thing.
Old Mar 30, 2010 | 07:52 PM
dakota Iceland
Question durango anyone
thanx for that i will ask but i highly doubt that they have it . Like I said in iceland and realy need to know if durango steering knuckle will fit on dakota ???
Old Mar 16, 2022 | 11:44 PM
KentuckyKid270's Avatar
KentuckyKid270
Default 99 Durango and 98 Dakota compatible?
I was told that a 98 Dakota 4wd steering knuckle will work on my 99 Durango 4wd.. can anyone confirm this?? I can’t find a Durango in my area but Dakotas are plentiful.
Old Mar 17, 2022 | 06:17 AM
Moparite's Avatar
Moparite
Look up part #'s on both and see if they cross.
Old Mar 17, 2022 | 11:26 AM
98DAKAZ's Avatar
98DAKAZ
Look on https://www.car-part.com/ most places will ship to you just ask.
But ask for some pictures be sent to you to inspect before you buy and remember even if they say its in good shape some places lie about its usefulness it may be junk.
its a gamble but worth the try
How much shipping may cost I don't know
You could have it brazed up drilled out and re threaded just use the caliper as a guide so its re threaded straight or have a machine shop do it all they can get it done.
Old Mar 17, 2022 | 11:29 AM
98DAKAZ's Avatar
98DAKAZ
( Look up part #'s on both and see if they cross. )
problem with that is no one sells them so nothing to check junk yards should know.
I do know a 2000 Dakota has different brakes than a 99.
98, 99, 2000 each year had different front brakes.
Old Mar 17, 2022 | 12:16 PM
KentuckyKid270
[QUOTE=98DAKAZ;3539868]Look on https://www.car-part.com/ most places will ship to you just ask.
You could have it brazed up drilled out and re threaded just use the caliper as a guide so its re threaded straight or have a machine shop do it all they can get it done.[/
thank you sir
Old Mar 19, 2022 | 12:28 PM
98DAKAZ's Avatar
98DAKAZ
Exclamation
[QUOTE=KentuckyKid270;3539874]
thank you sir
Just remember these pins don't need to be cranked down just around 25 to 30 torque I never used thread lock and they never came loose. when installing use caution you can cross thread them way too easy if its not easy to get in you have a problem back up retry.
Old Mar 20, 2022 | 01:09 PM
Dakota206's Avatar
Dakota206
Default 2006 dodge Dakota RED front driver side fender
hi I am looking to buy a front driver side fender in red but I can't seem to find one any ideas where I can get one or is anyone selling? Thanks
