Tune up questions
Old Jul 27, 2010 | 08:41 PM
  #41
bpark8824's Avatar
bpark8824
I forget but I can look in a bit, I still have the box in the garage. I put the old ones in the boxes the autolites came in...
Old Jul 27, 2010 | 08:48 PM
  #42
allmopar2003r/t's Avatar
allmopar2003r/t
got a question have 2003 durango 5.9 r/t 360ci with 68000miles got tranny overhualled at 60000 but now the thing has no passing gear it just wont downshift unless you put it in 1st or 2nd what do you think
Old Jul 27, 2010 | 08:49 PM
  #43
SpencerS's Avatar
SpencerS
are they 3923s bpark?
Old Jul 28, 2010 | 06:46 PM
  #44
bpark8824's Avatar
bpark8824
5224's. Thats the direct replacement for the OEM plug. There was a noticable difference over the worn out Champions. But I don't know when the last time they were changed was. I put about 20k miles on the them and the previous owner might have put a lot more on them. So it was definitly time...
Old Jul 28, 2010 | 07:37 PM
  #45
SpencerS's Avatar
SpencerS
the ones i pulled outa my truck were 5224s and they were worn. It was running ok, but i had been having some bad gas mileage problems. I put the 3923s in yesterday and im gonna go fill up my tank and see if there is a diff.
ive heard mixed things but i guess platinum core ones make the engine unhappy. Ive heard good things about these 3923 copper core ones. But we will see!
Old Jul 28, 2010 | 08:17 PM
  #46
bpark8824's Avatar
bpark8824
Plugs on this truck are so easy, it's nice.
Old Jul 30, 2010 | 02:15 PM
  #47
Rantz's Avatar
Rantz
Last night I decided to install my intake and figured I should do the plugs while everything was out of the way.
The rear plug on the passenger side of the engine was the toughest one to get to. I chose to do that one first since I would need two u-joints on either side of my extension.
My plugs were also worn with the gaps in them over double what they were supposed to be. HUGE difference now that I changed them.
Bit of advice: 1st) I kept a vacuum handy and sucked up all particles before I took my old plugs out to make sure nothing fell down int there once I removed them. Then I vacuumed adjacent areas again before putting new ones back in.
2nd) My spark plug socket was brand new and, as a result, the rubber padding inside of it was extra anxious to do its job. Unfortunately, it did such a good job, that the socket would stay on the plug and my extension would pull right out of it, leaving the socket in the hole with the spark plug. Because I have coils that reach way down to the spark plugs, the socket was unreachable. So I just unscrewed the spark plug again to get my socket back. Then I used a phillips screwdriver and wore down the rubber a bit so that it would allow the socket to release the plug.
