clicking noise
Old May 20, 2010 | 11:20 AM
dk1319's Avatar
dk1319
Default clicking noise
hi everyone, i have an 03 dakota and it makes a weird clicking noise all the time. when i look under the hood and try to hear where it's coming from it sounds like it's by the tensioner or idler gear but i don't think it's either one because the belt is in good condition and when the car is off there's no free play or anything. anyone ever have this before? btw it gets louder when you step on the gas but it doesn't go away when it's just idling.
Old May 20, 2010 | 12:04 PM
dbilik's Avatar
dbilik
What engine do you have?
Old May 20, 2010 | 12:37 PM
dk1319's Avatar
dk1319
4.7 liter
Old May 21, 2010 | 02:04 PM
dbilik's Avatar
dbilik
Could be your lash adjusters. If you have been running conventional oil and have a decent numebr of miles on it, they have been known to clog up. I am not sure how good it would work, but you could use a stethoscope and see if you can hear it louder by the valve covers.
Old May 21, 2010 | 09:44 PM
olsarge's Avatar
olsarge
Could be a broken exhaust head bolt allowing gas excape sounding like a click.
Old May 21, 2010 | 09:56 PM
rpowell's Avatar
rpowell
I have a small leak on my exhaust that gives off a ticking sound while cold (needs new gasket).
Are you sure you hear it coming from up top? Does it go away when warmed up?
Old May 21, 2010 | 10:58 PM
blackram1500's Avatar
blackram1500
It sounds like the exhaust bolt< cause I had the same sound and went to the service center and I had 2 of them broken and they had to replace the gasket also cause it was leaking and this was just yesterday
Old May 22, 2010 | 12:13 AM
rpowell's Avatar
rpowell
could be. I'll have to fix mine soon and find out.
Old May 22, 2010 | 01:46 PM
blackram1500
Check it out yourself and if that is it, fix it yourself if you can cause I didnt have the time and the service center charged me $437.00 for parts a labour...that really hurt. But if that is the case u wanna get it fixed cause if your manifold is leaking you can burn a valve
Old May 22, 2010 | 03:16 PM
lane338's Avatar
lane338
okay thanks guys. ill let you know if i fix it or not.
