What's this wire? (Also: Spark plug Q)
Old Jul 7, 2010 | 01:18 PM
magnethead's Avatar
magnethead
Default What's this wire? (Also: Spark plug Q)
When i was pulling the first driver side plug, I noticed first that the evap hose was unhooked, and second, that this wore was just dangling there. I put the hose back, but have no earthly idea where the wire goes? Truck runs fine (other than down on power form the plugs & oversize tires i'm thinking). The plu's gap is .047, judging from the center, i guess I should replace them. I'm no spark plug magician, can somebody ballpark how long they've been in the truck?
Old Jul 7, 2010 | 11:16 PM
Josh Abels's Avatar
Josh Abels
the wires proly a ground to somthing
Old Jul 7, 2010 | 11:19 PM
magnethead's Avatar
magnethead
That's the problem, i don't see any loose bolts, nor power sources, anywhere near where it would reach.
Old Jul 7, 2010 | 11:21 PM
Josh Abels's Avatar
Josh Abels
haynes manual is ur friend, find the wiring diagram that applies to it then itll tell u what it is, and maybe where it connects: frame, body panel, engine etc.
Old Jul 7, 2010 | 11:24 PM
magnethead's Avatar
magnethead
It goes into that loom, and from there I have no idea. I have the haynes and FSM, but no idea where to start
Old Jul 7, 2010 | 11:26 PM
Josh Abels's Avatar
Josh Abels
the loom doesn't go into any certain mechanical device or control module, it prolly goes right through the fire wall right lol
Old Jul 7, 2010 | 11:29 PM
dodgeramguy85's Avatar
dodgeramguy85
It might actually connect to the block but I would guess buy looking at it thats its a ground its not a power wire
Old Jul 7, 2010 | 11:34 PM
magnethead's Avatar
magnethead
That was my guess, but I wasn't about to dare find out the hard way (blowing something up).
Can somebody please look and see if they have a similar wire?
Old Jul 8, 2010 | 11:48 AM
cowboy63645's Avatar
cowboy63645
The plugs looked like mine, and after contacting the previoys owner, the plugs had been in the truck since he bought it, which meant there were 80,000 miles on them. The correct gap for a plug for the 3.9 is .040. Also, the wire is infact a ground, and if I can remember to, I will get my camera out and take a picture of where mine is located.
Old Jul 8, 2010 | 01:31 PM
magnethead's Avatar
magnethead
so the plugs are at about 3/4 life, and probably were gapped short (I dont know how much metal is lost over the life of a plug)?
An image so I can see where it goes would be appreciated. Makes me wonder why it's loose.
