CB Coaxal Feed, Help!
Old Jul 12, 2010 | 09:59 PM
SpencerS's Avatar
SpencerS
Default CB Coaxal Feed, Help!
So I went out and got me a CB and some antennas. I mounted the Antennas on the front of the bed right behind the rear window. The radio is mounted right under neath the dash to the right of the steering wheel.
Im looking for a way to run the Coaxals into the cab without going all the way underneath the truck and through the firewall. That would involve alot of zip ties and me kickin someones ***.
any ideas guys?
Old Jul 12, 2010 | 10:26 PM
01SilverCC's Avatar
01SilverCC
Look underneath the truck, in the general area where the front seats are bolted in. You should find a few drain holes with rubber grommets there that you can lift up the carpet from inside the truck and cut holes in the grommet, and run the coax in that way. Be sure to seal up the hole in the grommet with silicone or Permatex.
Jimmy
Old Jul 12, 2010 | 10:36 PM
dodgeramguy85's Avatar
dodgeramguy85
Just thought of this one might be able to bring it up where your 4x4 shifter is or bring it in the back door and along the carpet under the trim
Edit: wait do you even have the 4x4 shifter or do you have the **** on your dash totally forgot about that
Old Jul 12, 2010 | 11:31 PM
Josh Abels's Avatar
Josh Abels
when i had mine on my cab i just ran in through the drivers door then hid it in the trim on the side of the cab down to the floor under the floor side kick panel, then drivers kick panel, then under the carpet, so u could easily just run it through ur rear doors
Old Jul 13, 2010 | 01:58 AM
SpencerS's Avatar
SpencerS
yes i do have the shifter on the floor. thats a good idea ramguy! I will prolly end up gettin that done next weekend but for now im just run it in thru the rear doors like mr. ironfoot(ables) suggested. I can only do one for now since i have duals(coaxal doesnt reach far enough lol. Ill throw up pics here tommorow!
on a side note i know nothing about CBs i basiclly got it cause me and my friends are bored of txting. Anyways the word squelch made me laugh, oh the misinterpretation insued!
Old Jul 13, 2010 | 08:20 AM
Josh Abels's Avatar
Josh Abels
im new to cbs as well lol never actually used mine, the only reason i got it was for the PA so i could yell at ppl lol, the radio i got is frickin massive so i could never find a place to mount it, its a really old GE model that my step-dad had in the attic its got all the bells and whistles
Old Jul 13, 2010 | 11:19 AM
dodgeramguy85
They are pretty nice to have mine gets used for off roading and the other thing is talking to truckers when you in traffic lol
Old Jul 13, 2010 | 12:30 PM
Josh Abels's Avatar
Josh Abels
Aka finding out where cops r lol
Old Jul 13, 2010 | 02:41 PM
dodgeramguy85
Yeah but I also have a radar detector I took a trip to wv last week and forgot all about my cb but only saw 1 cop so it was all good.
Old Jul 17, 2010 | 09:33 PM
KillerKilgore's Avatar
KillerKilgore
""... got me a CB and some antennas..."
The standing wave (SW) with dual antennas is harder to set than a single antenna. Unless they are FAR part. Fire up a mike with the SW wrong and you can burn up a radio fast.
The length of coax you need is about 18ft. (SW comes into play here) and do not coil up the extra lay it under the carpet in a zigzag pattern.
But have fun and keep the clean side up and the dirty side down.
