ABS and brake light come on randomly
Old Oct 18, 2010 | 08:54 PM
ayoung101's Avatar
ayoung101
Default ABS and brake light come on randomly
my truck started lighting up the ABS and brake light simultaneously every now and then. i think today was like the 3rd time it's happened since i bought it in june. nothing seems to change. both lights always come on and go off at the same time. my brake fluid level is fine, and the ebrake isn't engaged. an OBD check didn't turn anything up. any ideas?
Old Oct 31, 2010 | 09:00 AM
ayoung101's Avatar
ayoung101
nothing? bump?
Old Oct 31, 2010 | 09:13 AM
McNasy's Avatar
McNasy
my thought would be the abs wheel sensors, speed sensors. if you have 4 wheel antilock the front hubs each have a sensor. 2 wheel abs has a speed sensor in the rear diff. thats all i got for you.
Old Nov 1, 2010 | 03:07 AM
cpberry1's Avatar
cpberry1
Same problem on a '99 was a rear wheel speed sensor - can't remember the price but it wasn't bad - $40 or $50 maybe. Easy to install - on rear differential. Hope this helps.
Patrick
Old Nov 1, 2010 | 08:36 AM
Jdb107's Avatar
Jdb107
speed/abs sensor in the rear diff
had the same problem and replaced mine a little over a month ago
Old Oct 14, 2011 | 09:46 PM
ahsnowlover's Avatar
ahsnowlover
I've had that problem and replaced the sensor in the top of my diff and it fixed for a while now occasionally they will stay on when started but if i shut the engine off and restart it they go off. What else can it be?
Old Oct 18, 2011 | 10:43 PM
mcvoss's Avatar
mcvoss
2001 3.9 Dakota I have the brake and ABS light coming on randomly, I replaced the rear wheel sensor and the lights are still coming on. Any suggestions?
Thanks
Old Oct 29, 2011 | 09:13 AM
EricBing's Avatar
EricBing
1999 dakota 318 2wd..I changed the rear wheel ABS sensor and change the rear diif gear lube, it gets loaded up full of metal "dust" (be sure to wipe off magnet in bottom of diff) and stick to the sensor screwing up the readings, Did it on my 99 and no probs since been over a 1 1/2 yr now
