2002 dodge dakota positrac
Old Oct 29, 2010 | 01:35 PM
syfudeath2013's Avatar
syfudeath2013
Default 2002 dodge dakota positrac
i want my 02 dakota sport to have a positrac rear end.... any recommendations?
Old Oct 29, 2010 | 03:10 PM
outlawfox13's Avatar
outlawfox13
Are you gonna race it? or you just want posi? Cause some came stock with LSD, or you could get a Tru Trac they have helical gears pretty sweet, or you could go with a locker manual or auto. What is your budget? and will you be installing?
Old Oct 30, 2010 | 04:17 PM
syfudeath2013
im wanting to race it. i have no take off with one tire spinning hahaha. my budget... well im a marine, i dont make much. but i do wat i can... i will be installng it though. i was thinking of finding one at a junkyard and and putting it on but im not sure what would have posi and fit the frame.
Old Oct 31, 2010 | 09:45 AM
outlawfox13
Ok a junk yard is a good place for a buget build, but you never know the condition the previous oner left it in. It is not real hard to put in an LSD or tru trac, as long as the gear ratio does not change. I am in the Army and on post we have an auto skills center where you can work on your own car real cheap, this is where I replaced my gears. Does the marine bases have somthing similar? you can also look on other sites to see if anyone is selling one. Also how many bolts are on your rear diff cover?
Also if you go the junkyard route, open the rear diff cover(since you wanna change the fluid any ways) and look at the carrier, on the driverside you should see clutch plates. this will tell you that it has a stock LSD. another route to help narow it down is to open the glove box and look at the options plate(a white sticker) and see if it says LSD on the rear it will also let you know if it is 3.55 or 3.92 ratio. If you are planning on racing, a 3.92 will give you some more take off.
Old Oct 31, 2010 | 12:47 PM
bpark8824's Avatar
bpark8824
Um, you will never have a posi, because all a posi is, is a GM coined phrase they used back in the day.
Are you looking for a locker or a LSD unit?
Old Nov 2, 2010 | 10:05 AM
syfudeath2013
ok well u know what i mean when i say posi trac. ok so i looked and i have a 3.55. im not great with drivetrain so bare with me haha. but i cant convert it to a 3.92? unless i change out the whole axle? and i know what lsd is, what is a locker?
Old Nov 2, 2010 | 10:35 AM
TheePlaymaker's Avatar
TheePlaymaker
is it 4x4 or 2wd if its 2wd you can change the gears no worries but if its 4x4 you gotta regear the front too.
Old Nov 2, 2010 | 10:38 AM
syfudeath2013
its 2wd. so i could go out and get like a tru trac 3.92 gearing and and put it in my axle with 3.55?
Old Nov 2, 2010 | 02:30 PM
TheePlaymaker
why wouldn't you just grab the entire axle with the 3.92 gearing wouldn't that be cheaper and easier in the long run unless there is something else wrong with it?
Old Nov 3, 2010 | 09:24 AM
syfudeath2013
well ive been having trouble finding any axles so i figure just get the new gearing. when ill actually do this itll be bout this time next year... i just want to know wat i need to get for everything im gonna do to my beast... haha...
