Towing a 4WD truck possible?
Old Nov 30, 2010 | 09:50 PM
McNasy's Avatar
McNasy
i have the 2001 AWD with the electric tranfer case. there is a neutral for button on it. the owners manual says its fine to tow it with the t/c in neutral.
Old Nov 30, 2010 | 11:32 PM
dbilik's Avatar
dbilik
I know it specifically says in the owners manual not to tow long distances with the two wheels up on a dolly or such.
As far as going into neautral, the transfer case can, but the trans has to be in park, so it doesn't move while you are towing. I guess it is because I owned a 1995 4WD Dakota and was always told that flat towing was not a good idea because of the transfer case. I am planning on hooking up brackets to my new bumper to allow for me to put a tow bar on if I ever need it. It is a nice option to have instead of having to rent a trailer.
As far as the 2000 Ram goes, I am not sure, I would be interested to know though. I think you have the NP213 transfer case in that?
Old Dec 1, 2010 | 12:22 PM
bpark8824's Avatar
bpark8824
Yeah the elctronic 4wd can go into nuetral. There is a little button you push with a pen or something small and pointy. Kinda like changing the time on a standard chyrsler HU.
Old Dec 2, 2010 | 07:41 AM
89newbie's Avatar
89newbie
Towed my 2004 with tow dolly about 300 mi. Followed towing instructions in manual. Only problem was rental dolly straps sucked, too short to stay tight. Lesson learned was think tow. I always carry tie downstraps so I secured Mr.Dakota with additional stuff to be sure he was secure. Good side was whenI returned the dolly the rental manager looked at the straps refunded me all but one day and explained straps were defective and it should hae never been rented with the straps in that condition.
Old Dec 3, 2010 | 04:10 PM
dbilik's Avatar
dbilik
I am specifically referring to a 4WD Dakota, which cannot be towed on a tow dolly without removing the driveshaft. And a 2WD Dakota can probably only be towed safely backwards or with the driveshaft removed. I think that is a general rule of thumb for a rear wheel drive vehicle.
Old Dec 4, 2010 | 05:18 AM
89newbie's Avatar
89newbie
Oh No! Now im wondering how much life I robbed from that 2004 Dodge Transmission! Guess I should have towed the 30 foot R.V. with the Dakota! LOL just picture that one big old motorhome being towed by a Dak.
Old Dec 5, 2010 | 12:11 AM
Dodge4lyfe's Avatar
Dodge4lyfe
With the TC in neutral, it won't be an issue. The big concern is the transmission output shaft spinning while the engine is off, which will shorten it's life because the pump isn't running and pushing oil through the trans. Having the TC in neutral will eliminate this issue. Oh, and FTR, I've flat towed my 95 4wd Dak behind an RV with no issues, was even told by Dodge dealer it would be fine, as long as tc stays in neutral.
Old Jun 1, 2014 | 01:37 AM
Yamaha guy's Avatar
Yamaha guy
Default flat towing my 2000 dodge dakota 4WD manual shilft
I was told that in order to flat tow, you must put your transfer case in neutral and that is true. But what gear do you put the gear shifter in? I am getting all kinds of answers on this one
Old Jun 1, 2014 | 12:50 PM
Robbadodge's Avatar
Robbadodge
I researched because I forgot the sequence.... copied this from a thread:
Stop vehicle in towing position.
Apply emergency brake.
Connect tow bar.
Connect towing lights.
Connect safety cables.
Connect emergency break away device.
Turn ignition key to on (first position to unlock steering wheel)
Depress brake pedal.
Shift automatic transmission to neutral.
Depress recessed transfer case neutral button for about 4 seconds.
Neutral light will come on.
Depress brake.
Start engine using key.
Shift into reverse.
Release brake pedal.
Determine that vehicle does not tend to move.
Shut engine off.
Place dummy key in unlocked on position.
Shift transmission to Park position.
Test towing lights.
Connect Brake Buddy and depress test button.
Remove fuse # 8 (Durango) to eliminate current drain of gear position indicator or
connect toad charge system.
Activate alarm system with key fob or door switch.
Unhooking vehicle:
Deactivate alarm system with key fob.
Bleed and remove Brake Buddy
Disconnect towing lights.
Disconnect emergency break away device.
Disconnect safety cables.
Disconnect tow bar and store it
Install fuse # 8 (Durango) or disconnect toad charge system.
Place ignition switch in the on position.
Shift automatic transmission to the Neutral position.
Depress recessed transfer case neutral button for about 1 second.
When light goes off release button.
Start engine with regular key.
Shift automatic transmission into Reverse.
Release emergency brake.
Old Jun 1, 2014 | 01:25 PM
00DakDan's Avatar
00DakDan
Section Moderator
It shouldn't really matter as long as the transfer case is in neutral. The oil pump is driven off of the output shaft so it will turn as long as the wheels are moving.
But, Dodge is quite clear that it is not recommended. Per the 2000 owner's manual:
DaimlerChrysler Corporation recommends towing with all wheels off the ground. Acceptable methods are to tow the vehicle on a flatbed or with one end of the vehicle raised and the opposite end on a towing dolly.
They go further, only in reference to a 2wd vehicle, by saying:
If the vehicle is to be towed more than 15 miles (25 km), it must be towed on a flatbed, or with the rear wheels raised and the front wheels on the ground, or with the front end raised and the rear wheels on a towing dolly.
