Bumper Covers
Sorry I forgot. It's the front one. I'm gonna try to bend the actual bumper back but the cover is cracked and bent. I haven't seen it in daylight yet but have looked online already and found a 98 dak at a local junkyard, this is an 02.
shold work. I have a 98 bumper assy on my 01. FYI depending how badly it's bent, you might get the plastic to go back. When I nailed a stop sign dead center, it went all the way in and bent my AC condensor. We hooked a tow rope around the bumer through the grille, to the ram. I held my brake on the floor and dad went on the classic running start to snap the rope tight. Took 3 pulls, but it eventally straightened out enough we could examine the damage to the condensor and radiator.
Yeah should work out fine.
Thanks magnethead. We are gonna try to pull it and get it more drivable (it is already but fan is hitting on something when first started). Then once its spring or warmer I'll check the yard, its like 12 degrees here and hard to work on a truck outside.
It's your radiator shroud, mine hit too. Apparently the toleraces are tight somewhere. If nothign else, just take sheet metal shears and/or jigsaw and/or sawzall and clearance as needed.
Trending Topics
We just hooked it up to some tow hooks on another truck, and pulled it. It actually pulled out about an inch and a half or 2 inches. That also caused the fan hit to stop (spun it by hand earlier and discovered what you were talking about). Last thing to do is get some more clearance by the front wheels, the bumper kind of pushed back a little and is rubbing when the wheel is turned. It's hard to explain, but I'll update as work continues.
The one right under the plastic is split in the middle but we kind of pulled it back together. Do you think it will hold up until like March or so? And yeah, it sucks just got some fog lights mounted NOT in the stock holes, 1 of the lenses is cracked now but it still works. Then the only other victim was the air horn, the lower one snapped off. Oh yeah then the grille and the hood is just slightly dented towards the center.
