Engine won't start
Old Jan 4, 2011 | 08:30 PM
wewanaplay's Avatar
wewanaplay
ok, if fuel pump works it shouldnt be ASD. I know you say you have no spark at the coil or dist. Do you have power? check with either a multimeter or test light.
Old Jan 4, 2011 | 08:58 PM
spanishgrass's Avatar
spanishgrass
There is no power at the coil.
Old Jan 4, 2011 | 09:37 PM
wewanaplay's Avatar
wewanaplay
oK, hmmm, I'm gonna stab in the dark and say to try a check on your crank or cam sensor. with no signal coming from them you wont have power at your coil.
Old Jan 4, 2011 | 09:50 PM
spanishgrass
Where would these be located?
Old Jan 6, 2011 | 06:47 PM
spanishgrass
Where could I get a wiring diagram for this vehicle. My Haynes manual is of no help and the dodge dealer has no available diagram. A factory manual from Chrysler Publications costs $95.
Old Jan 6, 2011 | 11:09 PM
bwdakrt's Avatar
bwdakrt
The cam sensor is under the dist cap...the flat disc looking deal with the 2 wires going to it. The crank sensor is on the passenger side back of the block when the bell housing meets the engine.
Old Jan 8, 2011 | 11:06 AM
spanishgrass
If it were a crank or cam sensor would there not be a check engine lite. I have pluged in my code reader and there are no codes. And yes the check engine does work. I removed the crank sensor, cleaned and reinstalled. Engine refuses to start.
