fuel rail fail, leaking gass
Old Dec 31, 2010 | 04:34 PM
thunder98110's Avatar
thunder98110
Thumbs down fuel rail fail, leaking gass
oh boy, noticed as i was ideling i was dripping gas eveywhere. found the bad injector. having a buddy comming over right to to lend me his tool kit. gotta pull the fuel rail and see whats up. called billy and he helped me and calmed me down. too bad its 18 degrees here. keep you guys posted.
Old Dec 31, 2010 | 04:42 PM
User's Avatar
User
That's how my 2000 burnt down.
Get all new o-rings and be sure the fuel rail and the injectors are snug and the o-rings are not damaged.
Old Dec 31, 2010 | 06:31 PM
thunder98110
damnit, cant get the injector off the rail
Old Dec 31, 2010 | 06:33 PM
User's Avatar
User
There is a small clip on the top you need to pull off, then turn the injector while rocking it back and forth in the hole...
Old Dec 31, 2010 | 06:34 PM
thunder98110
yea the clip broke. i can twist it but not far enough to get it to pull off. not enough slack it the wires
Old Dec 31, 2010 | 06:41 PM
User's Avatar
User
Im not talking about the red clip that holds the harness in place, im talking about the metal clip that keeps the injector attached to the fuel rail. Use a flat head and push back on it, it will pop off its metal.
The red clip you more then likely broke (they always do) you dont really need, just use a pen or something to push in the plastic clip to get the harness off the injector.
It would have been easier to just pull the whole fuel rail. Its not that hard to take off.
Old Dec 31, 2010 | 06:45 PM
thunder98110
duh. that took all of 5 seconds. thanks dude!!!!!!!!
Old Dec 31, 2010 | 06:51 PM
User's Avatar
User
No problem.
Old Dec 31, 2010 | 06:52 PM
thunder98110
Old Dec 31, 2010 | 06:54 PM
Blown287's Avatar
Blown287
Winston, you are in good hands I've meet Chris in person and he knows his stuff. Looks like you have found the culprit. Get some silicone spray, a new O ring and replace it. When it starts to warm up, I would probably replace all of them. When I pulled the heads off my truck I replaced every seal and O ring I could get my hands on, lol. Good job on getting it out.
