Bulb question for a 2k dak
Old Jan 6, 2011 | 02:05 AM
cycodude's Avatar
cycodude
From: Live: Silverdale, WA; Work: WA, CA, VA, GA, FL; From: WV
Default Bulb question for a 2k dak
I cannot find what the map light bulbs are. Everything says 579 but that is a wedge type bulb. These look like cartridge fuses. I want to turn everything red lit internally. Any ideas/suggestions?
Old Jan 6, 2011 | 05:47 PM
Time 2 Merc's Avatar
Time 2 Merc
Have you yanked the bubls out yet? I just ordered some for my dome light and made sure they were the correct ones. My dome light is a wedge type bulb and im assuming yours might be too. If you havent pulled them out yet go ahead and do so. Also some where in DF there is a post about all the bulb types.
Old Jan 6, 2011 | 06:22 PM
dodgeramguy85's Avatar
dodgeramguy85
Here you go.
http://www.modifiedlife.com/2000-dod...lb-size-guide/
Old Jan 6, 2011 | 07:15 PM
cycodude's Avatar
cycodude
Dome is a 579 wedge-type. The ones I'm looking for are the ones for the two map lights on the overhead console. They look like glass fuses and I can't seem to find out what they are. There is nothing stamped or etched on the bulbs.
Old Jan 6, 2011 | 07:31 PM
00DakDan's Avatar
00DakDan
Section Moderator
2k Dak out of the owners manual, switched dome - 578.
Try that.
Old Jan 7, 2011 | 11:59 AM
cycodude's Avatar
cycodude
Yep, it's a 578! My owners manual calls it a 579. I pulled one out and brought it in to work with me and it's stamped on the end cap in about 1mm lettering. Thanks!!!!
