having problems, startin to get angry
thats what my parents told me to do, bein in the navy i can get free help from somewhere just gotta find out where. also since my check engine lights on i thought it should be throwin a code. i dont have a scanner and cant drive it to advance auto to have them run it, isnt there a way to get the codes to show by turnin the key on and off or somethin?
and could someone check out this thread https://dodgeforum.com/forum/2nd-gen...half-runs.html sounds like he had the same problem and it was his crank sensor
After you install the new IAC sensor, disconnect the negative battery terminal for 1-2 minutes to reset the PCM. Reconnect the cable, start the engine and let it idle (DO NOT REV THE ENGINE) until it come up to operating temp, shur off the engine and restart.
If you don't do this you'll get a high and very irratic idle when you start it up.
