having problems, startin to get angry
so i got my 98 dakota rt back in october from a used car lot with 95,000 miles on it. within the first week i had to replace the battery. Then i guess they just had water in it so it froze and one of the hoses above the water pump busted so i took it to the dealership and had them fix it. i had to pay full price cause they said i only had a 30 day warranty. so ive had issues with what ive thought was a bad fuel check valve cause id have to turn it over a few times before itd start. then today i go out and it wont start unless my foots on the gas and as soon as i let off it dies. checked my paper work and found out i have a 12 month warranty so i called them and cussed em a lil bit, they said they'll have to call me back on monday. all i can say is i better get reinbursed for the last fix and get the new fix done free even if it is only a limited warranty. and idk what it could be this time either.
Could be many problems, vacumm line broken, sensors going out. 95K is right about the time everything likes to take a **** on you. One thing after another. On my 2nd dak, I just went all out and replaced all the lines, hoses, water pump, seals, sensors, suspension, ect when I got it. I'm at work and can't type out everything I need to say, but it could be many things causing it not to start, but I would take it back to the dealership and have them deal with it. I spent about 3K just replacing all the **** I listed.
well i just went and checked all the vaccum lines which all looked good. then i remembered some cars wont run if the oil is to low. so i checked the oil in it and none is reading? a week ago it was full of oil, it hasnt smoked and i dont see any leaks and when i drove home today it ran fine and oil pressure was in the normal. now im really confused cause oil doesnt just dissapear. also my check engine light is on when i turn the key on. but i dont wana try putting any oil or anything in it cause im worried the dealership would try to pull a fast one then sayin i tampered with it. normally i do my own work but im in the navy and in virginia and dont have the place or time to work on it myself
It has a warranty. So **** it let the dealership deal with it. So if it messes up even more just blame it on them. Take advantage of the warranty that they gave you. It might take 12months for them to figure out the problem but atleast u will have new parts and not a dime out of your pocket.
