4x4 differential
Old Jan 20, 2011 | 10:35 AM
  #21
UWAdventurer's Avatar
UWAdventurer
Forgot, 75W-90 for front and rear?
Thanks.
Old Jan 20, 2011 | 10:43 AM
  #22
thunder98110's Avatar
thunder98110
yeah both take the same. even if you put in a higher weight its going to be pretty much the same weight once its warmed up.
Old Jan 20, 2011 | 11:30 AM
  #23
dodgeramguy85's Avatar
dodgeramguy85
Originally Posted by UWAdventurer
So not using a gasket does not cause any clearance problems? Will check out the red RTV. Anyone know the torque spec on the bolts?
Thanks everyone.
I have never had a problem and thats how I did it on my truck just make sure you get all the old gasket off the cover and diff.
Old Jan 20, 2011 | 11:34 AM
  #24
thunder98110
i just did my hand tight. tq specs are over rated.the only thing we tq specd on my cam swap was the sprocket bolt. everything was just by feel. headbots ect snap too easily to mess around with torqing them to spec.
