trans fluid...and how to figure out what size rear dif
Old Jan 24, 2011 | 08:08 PM
dirtsurferus's Avatar
dirtsurferus
Default trans fluid...and how to figure out what size rear dif
I have a 2004 4wd with the 4.7. My truck did not come with a user manual. I looked under the hood for the gear ratio but there aren't any stickers under it. Also when I was in auto zone pricing fluid that truck has a 9 1/4 and 8 3/4 rear end??? Or something like that... how do I tell what size rear end and gear ratio I have? My next question is I have 5 spd trans what kind of fluid do I change it with and how do I do it? I know that automatics are the only ones that have fluid but dont manuals need gear oil or something?
Old Jan 24, 2011 | 08:29 PM
UWAdventurer's Avatar
UWAdventurer
Look in your glove box for rear end info. I have an automatic, sorry don't know what fluid you need.
UWAdventurer
Check your dipstick, I would think it would tell what you need on it.
Old Jan 24, 2011 | 09:40 PM
Josh Abels's Avatar
Josh Abels
if your diff cover is round, u have the 8.25, if its more like a stop sign its the 9.25, its most likely the 9.25 with 3.55 gears but check ur glove box like above for the the gear ratios
Old Jan 24, 2011 | 10:56 PM
00DakDan's Avatar
00DakDan
Section Moderator
The NV3500 has a drain plug on the bottom and a fill plug on the side. It's not hard to do. It does not use gear oil it takes a special oil. You're best off getting it at the dealer, the NV3500 seems to have issues with other oils.
The FSM says: Required lubricant for the NV3500 is Mopar Manual Transmission Lubricant, P/N 4874464. This is the only lubricant to be used in NV3500 transmissions. No other lubricants are acceptable, or recommended.
You should find a tag on the differential cases with the ratios.
Old Jan 30, 2011 | 03:18 PM
dirtsurferus
thanks guys. and do you know of anywhere that i can get the trans lube? like online or something? i hate paying such rediculous prices from the dealers....
Old Jan 30, 2011 | 03:20 PM
thunder98110's Avatar
thunder98110
you are pretty much going to pay a pretty penny for mopar atf+4. do some google searches and see if you can get it cheaper.
Old Jan 31, 2011 | 10:59 AM
00DakDan's Avatar
00DakDan
Section Moderator
It's not ATF+4, it's special for the NV3500.
I'd stick with the Mopar fluid as you know what you've got. GM also has an NV3500 fluid of their own, you could check prices. I know it is pricey but so is the transmission. It's not like you'll need to change it often anyways.
I''m surprised the "Oil Guy" hasn't jumped into this.
Old Jan 31, 2011 | 12:03 PM
DakMan6704's Avatar
DakMan6704
I run royal purple. Have since umm...maybe 20K? no issues. Smooth shifts and solid. I think its Synchro-Max that I use. Then Max Gear in the front and rear diffs.
if you have the 3.55 gears, say, 2000rpm around 60-65, you have a 9.25. Like Josh said...
my 2cents, no need for dealer ish. With a little digging you could prob find Mopar fluid is made by "_____", and you can prob get that for 30% cheaper. (note, I dont know who makes it, or care cause Ive had no issues with Royal Purple.) Also, People run Lucas fine, or im sure reg ATF+4. I believe the manual says something funny like, only use mopar filters and a mopar approved oil...its all similar. I wouldnt give my dealer the pride of the business for a simple fluid. Also, its out of warranty, so who the ell cares! lol...
Old Jan 31, 2011 | 12:06 PM
DakMan6704's Avatar
DakMan6704
also, there is a tag conveniently located under your carpet and passenger seat( i think) that has your build codes on it...if you cant make a positive decision, not that it will be hard to figure out or differentiate.
