The Biggest Tire On A Dakota?
Old Apr 7, 2012 | 11:36 PM
  #41
moe7404's Avatar
moe7404
NOTE: dont crank the torsion bar bolt to bottom out, it will cause the rubber bushings to blow out.
Old Apr 8, 2012 | 03:22 AM
  #42
Dakota Greg's Avatar
Dakota Greg
Originally Posted by dodgeramguy85
No my sig pic is back during the summer. I need to find a good place to get a new one cause now I have 32's and black wheels
Hey not meaning to hyjack butt, isnt it akward that the Ram 2500 came stock with 30's and we are putting 30-33's on our little dakotas? Sounds like you need some 37's
Old Apr 8, 2012 | 12:19 PM
  #43
barrysuperhawk's Avatar
barrysuperhawk
Not every 2500 runs lifesaver tires......here's a guy on 37's and STOCK.
http://www.cumminsforum.com/forum/ti...-big-meat.html
Old Nov 25, 2012 | 02:25 PM
  #44
III%'s Avatar
III%
It appears you put the new tires on stock 7.5 inch rims. They belong on minimum 8 inch rims. I moved from the original 235/75R 15 to 31x10.50 R 15 last tire change I'm about to move up to 32's but will swap the rims out for a ZERO offset wheel, which will move the center of gravity by widening the base. The larger sidewalls make the ride unstable in turns if you don't spread them out on wider rims to minimize flex. My front end is torqued all the way up and I had new rear leafs added with an extra leaf. That also raised the center of gravity making a white knuckle ride going through mountain roads with a full load of firewood. Remember also, when you go up in tire size, you throw off your speedometer. I just went one size and my GPS says I'm doing 75 when the clock says 70. Easy to get a ticket. And another safety issue is your brakes are going to work a lot harder to stop you now, so leave a little extra space between you and the vehicle in front of you.Especially if you have ABS. But hey... at least we'll look cool.
Old Nov 27, 2012 | 04:23 PM
  #45
Robbadodge's Avatar
Robbadodge
Originally Posted by ryan_brown33
thats because on a 16 inch rim the sizes are metric, you arent going to find a 31x10.50x16 because its not made. equivalent would be a 265/75-16. its the same width as 265/70-16, just the sidewall is 5% larger/taller. this is what i run on my 02 QC 4.7 and it fills out the fenders better, and didnt rub on mine (really close though) but i think it looks a lot better. you could also do a 275/70-16 (not as common but there still are tires made in that size) which will be 10mm wider and just a little bit taller. if it were me i would just run 265/75-16 though
Hey Ryan,
The little increase in height does look great. We basically have the same truck; only mine is the '01. I read so much about needing to crank this or cut that, I didn't want to chance going with 75's.
Now, reading this thread to the end, I found your post. One question, If you have no rubbing, didn't have to adjust TB's, and you didn't change gears... then what handling characteristic do you feel changed?
I recently got the Firestone Destination AT's and love the look and grip. I stayed with the 265/70/16 because I didn't want to get into the truck modifications, but I also didn't want to give up cornering sidewall stability. Perhaps this would be a little give and take for choosing what may be more important.
I off-road more today than ever, but I still drive up to several hundred miles per day in my sales position. Interested in hearing input regarding my typical long haul driving, corning desire and off road handling with either tire size.
Thanks!
Robb
Old Jun 7, 2018 | 07:41 PM
  #46
Duder98's Avatar
Duder98
Default 2003 Dodge Dakota on 315/75r16
add pictures
I know this is an old thread but 315/75r16 can be done with a 3" body lift and torsion crank. Also used spacers 1" and 1/4 in front and 1/4" rear. Did alot of cutting because I off road often.
