2000 4x4 rims - help!
Old Feb 3, 2011 | 11:04 AM
Gundyy's Avatar
Gundyy
Default 2000 4x4 rims - help!
Hey, I'm looking to get new/used Rims for my truck. I want the biggest tires I can fit with 0 lift which is 30 or 31" I believe? With the stock 6x4.5" bolt pattern... What are my best options? 15,16, or 17" rims and what's the best width? 8, 8.5, 9 or 10? Or is it easier to change the hub to a different bolt pattern to open more options?
Old Feb 3, 2011 | 11:07 AM
thunder98110's Avatar
thunder98110
if you crank the tb's you can fit 285's. 265's are stock size. if you do off roading a smaller rims is recommended.
Old Feb 3, 2011 | 11:53 AM
Gundyy's Avatar
Gundyy
285x?? What? What do I need to crank the TBs? That would give me what like two inches? Then add a leaf in the back? I just want it to look a bit bigger, lift offroading. Any suggestions from summitracing preferable black rims
Old Feb 3, 2011 | 11:59 AM
thunder98110
get a 3 inch body lift. and 285/70/X (rim size)
Old Feb 3, 2011 | 12:06 PM
Gundyy's Avatar
Gundyy
Ahhh but that's another 300$ no? and 285/70 is perfect!
Ps I love your videos I also just did my dash blue
Old Feb 3, 2011 | 01:24 PM
TheePlaymaker's Avatar
TheePlaymaker
stock backspacing and 8" wide rim can fit 32's, with about a 1" tb crank, whatever that is in metric IDK but with wider back spacing or wider wheel it would most likely rub more
Old Feb 3, 2011 | 04:14 PM
Derek2002's Avatar
Derek2002
For wheels you might try Crager soft 8's.I got them and love them and they are less than $50 a piece.If you do get them I would not recommend the Crager center caps.Mine started rusting in 2 months and now they are covered in rust.I plan on buying new center caps and lug nuts soon.
Old Feb 3, 2011 | 08:38 PM
Gundyy's Avatar
Gundyy
okay sweet, so i could buy these now, put my current tires on while waiting to do the lift. do 3" lift then slap on some bigger tires. solid plan?
