low temp thermostat?
A thinner wallet.
Some people say they notice some more performance but you'll be using more gas to get it.
When the engine is colder the pcm will retard the ignition timing and richen the fuel mixture slightly. Both good to reduce detonation.
If you have a tuner or something I could see using it. If you're mostly stock I wouldn't bother.
Dodge designed the engines for a 195. That's why I stick with it.
