2000 dakota no power at ignition
Old Feb 15, 2011 | 05:21 PM
00DakDan's Avatar
00DakDan
Section Moderator
OK, you have power to one side of the fuse, how about the other? Did you check the fuses with your meter?
The other place to check would be at the ignition switch coming off the fuses. It'll be pins 4 and 7. Both should have +12 available all the time, its before the switch.
Old Feb 15, 2011 | 11:30 PM
dakoman859's Avatar
dakoman859
there was only power on one side of the fuses and do you mean the long ignition switch plugin
Old Feb 16, 2011 | 09:59 AM
00DakDan's Avatar
00DakDan
Section Moderator
Yup, at the plug in to the switch. Pin 7 should be RED, Pin 4 Pink with a Black tracer.
Those two lines feed the start and run positions on the switch. Power there will come right from the PDC through the big connector, C200, behind the brake pedal.
Old Feb 16, 2011 | 10:36 AM
dakoman859's Avatar
dakoman859
k thanks ill go check then ill get back to ya in a few minutes
Old Feb 16, 2011 | 12:32 PM
dakoman859's Avatar
dakoman859
ok in order from the seat to the dash they go
(red / black / black-orange stripe /pink-black stripe / none/ blue/ yellow) there is power coming to the pink on but none to the red one and there is only six wires
Old Feb 16, 2011 | 01:11 PM
00DakDan's Avatar
00DakDan
Section Moderator
The red needs to have power or the starter relay in the PDC won't trip. Double check that fuse, it should be #10. Swap the fuses if you have too, just to see if you then get power on it so as to eliminate a wiring problem.
That's red with NO stripes. There should be 7 openings on the connector for the ignition switch, only 6 are used
Old Feb 16, 2011 | 01:29 PM
dakoman859's Avatar
dakoman859
i aint sure if i mentioned it but i dont have any gauges or sterio of nothin im gonna run out and try changin that fuse
Old Feb 16, 2011 | 01:54 PM
dakoman859's Avatar
dakoman859
good news i found a blown ignition fuse n replace it n now we got power to the red wire and the pink but she still wont go
Old Feb 16, 2011 | 02:04 PM
00DakDan's Avatar
00DakDan
Section Moderator
Yeah, the 40 amp fuses are like the mains they feed the ignition switch and then go back to the fuse box to feed some of the accessories through smaller fuses. You did tell me earlier, that's why I suspect the fuses are bad. No power seems to confirm it.
The stereo for one is fed via the red wire.
Old Feb 16, 2011 | 02:05 PM
00DakDan's Avatar
00DakDan
Section Moderator
What happens now?
Does the stereo work?
