1999 tune up
Old Feb 26, 2011 | 04:41 PM
christianwarrior's Avatar
christianwarrior
Default 1999 tune up
I am planning on doing a tune up on my dak and was wondering what would be the easiest way to do it my self?
Old Feb 26, 2011 | 05:29 PM
Lebbie54's Avatar
Lebbie54
What are you planning on doing to it exactly? Are we talking change the spark plugs and oil kinda of tune up or we talking engine rebuild kind of tune up?
Old Feb 26, 2011 | 05:32 PM
bigreed91's Avatar
bigreed91
I consider a tune up as plugs, wires, oil and filter, air filter, and a bottle of injector cleaner every now and then
Old Feb 26, 2011 | 06:45 PM
Lebbie54's Avatar
Lebbie54
Well if you are talking that for tuneup then go for it. Some people do more some people do less.
Old Feb 26, 2011 | 07:13 PM
bpark8824's Avatar
bpark8824
Not quite sure what you mean by easiest way... A 'tune up' is pretty straight forward. You're probably talking plugs, wires, cap, rotor, air filter, oil & filter, and if its an auto; a tranny flush.
Everything except the trans flush is pretty straight forward. If you're unsure on how to do some of the things, get a haynes service manual. That will help you get the firing order right if you get things mixed up changing wires and what not. If you need any more information let us know.
Old Feb 27, 2011 | 12:45 PM
christianwarrior
yeah srry bout that i meantbthe easiest way to get the right wires to the right place
Old Feb 27, 2011 | 03:14 PM
bigreed91's Avatar
bigreed91
Not tryin to thread jack but i just went to change my plugs and realized theres some heat shields around the plugs and my plug socket wont fit, can i pull these off or do i have to go find a thinner walled socket
Old Feb 27, 2011 | 03:30 PM
00DakDan's Avatar
00DakDan
Section Moderator
Christian, it's best to replace one wire at a time. Just follow the original path.
Old Feb 27, 2011 | 04:09 PM
bpark8824's Avatar
bpark8824
Or get some tabs that you can stick on them in order to label them. It's hard to do one at a time if you're replacing the cap and rotor too.
Old Feb 27, 2011 | 05:08 PM
UWAdventurer's Avatar
UWAdventurer
Make a diagram to keep your wires straight if you need to. That is what I do. Or hold the orientation of the cap and set it somewhere with the wires on it where you can trace the wires from the plugs back to the cap one at a time.
