Good price for work done at shop?
Old 03-04-2011, 02:58 PM
PacificDakota's Avatar
PacificDakota
PacificDakota is offline
Default Good price for work done at shop?
Hey I'm new here and I hope to get some good advice about getting some work done on my Dakota.
I've got a 2000 Dakota 4X4 V8 4.7 club cab with canopy.
I'm running some 31/10.5R15 LT 109R Michelin XCX/APT Radial X tires on the stock 15 wheels.
I've got a quote from a local auto shop about getting some work done to my truck and I hope to get some good advice from you guys on whether or not this shop is quoting me a "decent" price for the work. I wish I had the tools and a garage to get this stuff done myself but I don't so I gotta go shop.
Anyway here's the roster:
FLUSH BRAKE FLUID- COMPLETE ( FLUID IS DISCOLORED)$109.00 PLUS TAX
FLUSH COOLING SYSTEM INCLUDES PRESSURE TEST COOLING SYSTEM,
INSTALL NEW ANTIFREEZE & INSPECT SYSTEM FOR LEAKS ( SYSTEM APPEARS DUE FOR
SERVICE) $ 139.00 PLUS TAX
LAST POWER STEERING FLUSH? FLUID SMELLS BURNED $159.00 PLUS TAX
RIGHT HAND TAIL LIGHT LENS IS BROKEN $ 169.00 PLUS TAX INSTALLED
REPLACE SPARK PLUGS$ 289.00 PLUS TAX ( COILS ARE MOUNTED ON TOP OF THE PLUGS
AND MUST BE REMOVED FOR ACCESS)
CHARGE A/C SYSTEM AND TEST FUNCTION $ 198.00 PLUS TAX
REPLACE ALL EXTERNAL BULBS TO INCLUDE HEAD LAMPS $ 139.00 PLUS TAX
POLISH HEAD LIGHTS $89.95
AIR FILTER IS OK- RECHECK IN 3000 TO 6000 MILES 0.00
DRIVE BELT IS OK- RECHECK IN 3000 TO6000 MILES 0.00
TRANSMISSION FLUID IS OK- RECHECK IN 3000 TO 6000 MILES 0.00
FUEL FILTER IS IN TANK AND IS PART OF THE FUEL PUMP ASSEMBLY 0.00
NEEDS REAR BRAKE INSPECTION - FREE WITH ANY OTHER SERVICE
Balance all four tires and rotate as needed
All for 1149.00 plus tax
So, there it is. Any and all help on this is much appreciated, Thanks.
Old 03-04-2011, 03:21 PM
thunder98110's Avatar
thunder98110
thunder98110 is offline
RIGHT HAND TAIL LIGHT LENS IS BROKEN $ 169.00 PLUS TAX INSTALLED ebay for 30bucks
AND MUST BE REMOVED FOR ACCESS) other than pice of plugs do it yourself, 30minutes tops. your getting raped here.
REPLACE ALL EXTERNAL BULBS TO INCLUDE HEAD LAMPS $ 139.00 PLUS TAX- raped. do it yourself for free
POLISH HEAD LIGHTS $89.95 -double rape. buy turtle wax rubbing compound at walmart for 5 bucks and do it your self.
Old 03-04-2011, 03:22 PM
thunder98110
if you need help doing spark plugs or any other maint. please ask. I hate to see you spend over a grand on stuff you can do yourself.
all you need for the spark plugs is a 10mm for the nut holing in the coil and a extension and a spark plug socket.
Old 03-04-2011, 03:50 PM
PacificDakota
awesome stuff thunder!
thanks for the help!
Old 03-04-2011, 03:52 PM
jondakotaguy's Avatar
jondakotaguy
jondakotaguy is offline
I was just thinking.. you can come to my house and I will do all that work for you for that price ^_^.. seriously though.. thunder hit the nail on the head.. getting screwed on each thing.. most of that you can do your self for the cost of a few hand tools.. and your time.. & parts
Old 03-04-2011, 04:17 PM
PacificDakota
thanks again thunder!
here's the reply I just sent to the shop.
not sure if it's going to **** them off or if they will work with me.
keeping in mind that 605.00 is the total for the list of things to get done after adjustments to the list were made.
will post the reply from the shop when I get it.
here's the reply I sent:
I've done some looking around and I think I'll make some adjustments to the order/roster of work to be done on Tuesday.
here's a rundown of what I would like to minus from the list of work to be done;
included in this rundown is some comments/advice that I've recently received from a forum.
AND MUST BE REMOVED FOR ACCESS) other than price of plugs do it yourself, 30minutes tops. your getting raped here.
That was just a copy and paste from a dodge forum I was just on.
so to re-cap again, for the work I would like to get done;
1149.00 minus the above 686.95 is about 462.05 plus tax, unless you can do better than that for me?
so, what is the best you can do for me to complete the following work???
AGH FLUSH BRAKE FLUID- COMPLETE ( FLUID IS DISCOLORED)$109.00 PLUS TAX
AGH FLUSH COOLING SYSTEM INCLUDES PRESSURE TEST COOLING SYSTEM,
AGH LAST POWER STEERING FLUSH? FLUID SMELLS BURNED $159.00 PLUS TAX
AGH CHARGE A/C SYSTEM AND TEST FUNCTION $ 198.00 PLUS TAX
AGH AIR FILTER IS OK- RECHECK IN 3000 TO 6000 MILES 0.00
AGH DRIVE BELT IS OK- RECHECK IN 3000 TO6000 MILES 0.00
AGH TRANSMISSION FLUID IS OK- RECHECK IN 3000 TO 6000 MILES 0.00
AGH FUEL FILTER IS IN TANK AND IS PART OF THE FUEL PUMP ASSEMBLY 0.00
AGH NEEDS REAR BRAKE INSPECTION - FREE WITH ANY OTHER SERVICE
Old 03-04-2011, 04:28 PM
PacificDakota
Hey Jon,
If you weren't so far from Washington State, Texas....I'd take you up on that. Living in an apartment right now and not having a garage sucks.
and yep, sending that email did **** them off.
the shop guy just gave me a call, to try and justify/flap his jaw...about how their service for the "raped" items were a fair price and how their book was saying at least and hour and change to do the spark plugs. the guy also tried to hook me in by telling me about how he had "already ordered the tail light because I told him to".
ended the call with "I'll just go somewhere else then"
it was obvious that they didn't want to work with me after this.
too bad for them, even thou they have great testimonials on their website.
Old 03-04-2011, 04:56 PM
jondakotaguy
I would suspect being told I was raping someone on price or accusing of raping.. or being called out on raping would **** me off too.. HA HA...
If you go to another shop.. dont be afraid to haggle them down off their price.. be like 90 bucks to replace a few bulbs for real? You can not combind that with other service and give me a discount.. stuff like that..
Mechanics are not cheap.. they are going to charge you well over what it's worth because frankly.. its either pay their price.. or do it your self.. or go somewhere else..
just try and talk to them.. and really think about your responses and how you word them.
Let them know your not some *** hole but at the same time your no idiot either.. If they want the work they will work with you some what..
Last edited by jondakotaguy; 03-04-2011 at 05:09 PM. Reason: My Computer is having an ID10T Error..
Old 03-04-2011, 05:18 PM
jondakotaguy
Best Advise..
Go get these....
To bend over like this...
To get you a better deal... and if they are alittle bit funny.. go grab one of these..
And tell them to
Last edited by jondakotaguy; 03-04-2011 at 05:23 PM. Reason: This reply is so innapropriate.. but so funny!!!!!!
PacificDakota
you right Jon,
they have a business to run and etc. getting called on bs would **** off most folks.
I imagine especially if that bs was called and then broadcasted, it would loose some business for them. I can understand a price for honest work but that crap is over the top.
I normally don't go thru all the hassle like this. I was really curious about all the shop's hype about being the best in town and etc. it's just that I keyed up on the fact that this shop depends and prays upon the lazy and uninformed and then has the gaul to talk to their potential customers as if they were stupid.
with all of that aside, I'm glad to be here and really appreciate that you guys do what you do. Now that I have a roster of some things that I am just too lazy to do for myself (mostly due to a lack of having a garage), I will see if I can haggle a decent price from a competing shop. The rest of the stuff, I will stab away at it while I have no rain here and there.
Quick Reply: Good price for work done at shop?
