2001 Dodge Dakota 4.7 HELLLPPP PLLLEEASE
Old Mar 19, 2011 | 09:25 PM
RuelJenkins's Avatar
RuelJenkins
Default 2001 Dodge Dakota 4.7 HELLLPPP PLLLEEASE
I have a 2001 dodge dakota 4.7L v8
When i insert spark plug into #2 pre gapped at .40 and start the truck, it knocks loud so i took the plug back out of #2 and this is the result. It f**ckd the spark plug all up.
I check spark plug #4 and its fine. These are newly bought spark plugs.
Please any ideas? I'm guessing the lifter is broke or bend? any advice is appreciated.
Old Mar 20, 2011 | 12:26 AM
RuelJenkins
Any Ideas? Please!
Old Mar 20, 2011 | 06:34 AM
wewanaplay's Avatar
wewanaplay
Plug looks a bit longer in the pic. I would measure it against the others. Of course, im not a 4.7 guy either so someone else may have an idea. How does it do if you put the old plug back in?
Old Mar 20, 2011 | 10:50 AM
thunder98110's Avatar
thunder98110
did you buy the right plugs?
Old Mar 20, 2011 | 11:29 AM
00DakDan's Avatar
00DakDan
Section Moderator
The lifter won't do that. The valves clear the spark plugs.
What are the chances something fell into the opening and is now damaging your spark plugs?
Old Mar 20, 2011 | 12:08 PM
01KotaQuad's Avatar
01KotaQuad
u need shorter plugs..it's happened before. u can tell in the pic it's slightly longer...
Old Mar 20, 2011 | 03:45 PM
RuelJenkins
all the plugs are the same size though. I know they are cheapy plugs but they are all the same size plugs and i checked the rest of em, theyre fine.
Should i put washers on that #2 plug to try to clear the valve?
Old Mar 20, 2011 | 04:07 PM
01KotaQuad's Avatar
01KotaQuad
uhhhh, i wouldnt... i don't think you will get the spark u need it u do that... if there the same size something HAD to of falling in there....instead of using a washer bro i would just go buy some that have shorter thread to be safe....
Old Mar 20, 2011 | 04:29 PM
RuelJenkins
hmmm. well if i can find any shorter ones that are compatible with my truck i will. but first i think im going to try and vacuum out the hole and see if i get anything out of it.
Old Mar 20, 2011 | 06:45 PM
RuelJenkins
I just pulled all these little peices of metal out of that #2 park plug hole.
Any ideas on what it is?
