Lost wire
Old Mar 30, 2011 | 01:26 PM
frydaddy82's Avatar
frydaddy82
are you sure it doesnt go to the alt? i know theres a hot wire comin from the battery to the alt on most motors.
Old Mar 30, 2011 | 05:36 PM
hirise123's Avatar
hirise123
I hooked up the wire to the alt battery terminal. Then I started getting 01 $ 02 oxy senser failure codes plus the random miss fire codes. Drove it a bout 10 miles, It tried to die several times and the idle would rev up and down. Then there was no throttle, I turned the key off then on It started all right and ran good for about a mile then started all over again.
Old Apr 8, 2011 | 01:50 PM
hirise123's Avatar
hirise123
I found out where the wire went. It is a ground wire that goes to the air compressor. The reason it was hot was it was feeding from the air compressor.
Old Apr 9, 2011 | 10:11 AM
sl2racer's Avatar
sl2racer
ahhhhh
