Lost wire
Old Mar 29, 2011 | 07:52 PM
hirise123's Avatar
hirise123
Default Lost wire
Hi, I replaced my water pump on my 2000 Dakota V6. Every thing went good except I have a black wire with a large terminal left over, I can't find where it goes. It comes out of the cross over bundle just behind the alternator, it is hot when the key is on. The engine is throwing random misfire codes for #2 & 4 cylinders. Ran good before replacing the water pump, also the air compressor does not kick in. Thank you
File Type: jpg
Old Mar 29, 2011 | 08:41 PM
jasonw's Avatar
jasonw
Site Moderator
I will move this to the Dakota section for you.
alegar's Avatar
alegar
Sounds like you have a lose ground. Chances are that is what you got there a ground, black is pretty well the universal ground color.
Old Mar 29, 2011 | 10:39 PM
01KotaQuad's Avatar
01KotaQuad
I would say ground as well....prolly goes to the frame...
Old Mar 29, 2011 | 11:10 PM
McNasy's Avatar
McNasy
well... if its hot when the key is on we will not try to ground it. just my thought. i will look at mine in the morn to see if i can find where it goes.
Old Mar 29, 2011 | 11:18 PM
dodgeramguy85's Avatar
dodgeramguy85
If its hot when the key is on its not a ground. Can You get a pic of it?
Old Mar 29, 2011 | 11:49 PM
hanleysh's Avatar
hanleysh
Thumbs up for that one, was just reading this thread and contemplating my reply but you beat me to it
Old Mar 30, 2011 | 10:01 AM
sl2racer's Avatar
sl2racer
to me it looks like a wire that would normally be on the backside of the alternator. i'm only guessing though
Old Mar 30, 2011 | 10:33 AM
hirise123's Avatar
hirise123
Thank you every one, I have rechecked where it would go. Putting it to ground doesn't change any thing. the wire is hot so it shouldn't go to the alt.
Old Mar 30, 2011 | 11:21 AM
01KotaQuad's Avatar
01KotaQuad
Oops....missed that part
